Hi there, I have an assembly with few RC Servo motors. After assembly I realized that the “0” position is not the same for all motors. I have a Maestro board for driving the motors.
Is there a way to “reset” the “0” position of the servo so all servos are exactly at the same angle?
Thank You,
Cristian
Hello, Cristian.
Could you clarify what you mean when you refer to a 0 position? For example, do you mean the position of the servo that corresponds to a pulse width of 1500µs?
Hi Brandon, I am referring to the neutral position corresponding to 1500µs.
Unfortunately, that is not something that the Maestro controls; you would need to reprogram the servos’ internal electronics (which isn’t always practical). You might be able to get them a little closer by re-orienting the servo horn on the spline. Otherwise, you could use an offset for each servo channel to get them to line up.
