Reset mini maestro
Using the “Reset to default settings…” option will wipe the script from the Maestro, but not from the “Script” tab of the Maestro Control Center. You can just delete it and “Apply Settings”.
However, this generally should not stop you from using the “Status” tab to control your servos. Could you post more details about your setup (including information about your servos and power supply) and what you’re doing? Please include some pictures of your setup that show all of your connections.
