Is it possible to replace the potentiometer on a Pololu Adjustable 9-30V Step-Up Voltage Regulator U3V50AHV with resistors to get a constant 18v output?
We have wiped the pots and they do not adjust the voltage anymore.
You can remove the potentiometer and replace R5 with a 220K resistor and R6 with a 16.2K resistor to get 17.92v out. If you would like a bunch pre-made this way, please contact us at support@pololu.com.
