Hey, guys, I am currently using an l293d in my robot to drive to 2dc motors but now for my project, I need to use 2 12v motors with higher power consumption so obviously l293d can’t handle more than 1A so if I were to replace the l293d with Pololu Dual VNH5019 would I need to change the code or can I use the same code as below and also as for the schematic of this new motor driver I am confused about what is the use of M1/M2PWM pin on the motor driver?
#include <IRremote.h>
Left Motor
// IN 1
#define LM_IN1 2
// IN 2
#define LM_IN2 4
Right Motor
// IN 3
#define RM_IN3 5
// IN 4
#define RM_IN4 7
// IR receiver
# define RECV_PIN 10
IRrecv irrecv(RECV_PIN);
decode_results results;
//HEX codes for buttons
#define FWD 0xFD8877 // go forward
#define LFT 0xFD28D7 // go left
#define RGT 0xFD6897 // go right
#define BWD 0xFD9867 // go backward
#define STOP 0xFD30CF // stop
#define RESET 0xFD00FF // Resets the Arduino Board(RED)
unsigned long int value=0;
************Arduino Reset Pin**************
#define RESET_PIN A0
void setup() {
// set mode of the pins as output
for (int i = 2; i <= 7; i++) {
pinMode(i, OUTPUT);
// start serial communication
Serial.begin(9600);
// In case the interrupt driver crashes on setup, give a clue
// to the user what's going on.
Serial.println("Enabling IRin");
irrecv.enableIRIn(); // Start the receiver
Serial.println("Enabled IRin");
void loop() {
if (irrecv.decode(&results)) {
value = results.value;
Serial.println(value, HEX);
irrecv.resume(); // Receive the next value
delay(200);
delay(100);
check_Inst(value);
value=0;
void check_Inst(long int value) {
switch (value) {
case FWD:
go_Forward();
break;
case LFT:
go_Left();
break;
case RGT:
go_Right();
break;
case BWD:
go_Backward();
break;
case STOP:
go_Stop();
break;
case RESET:
pinMode(RESET_PIN,OUTPUT);
digitalWrite(RESET_PIN,HIGH);
break;
default:
value = 0;
void go_Forward() {
movement_Inst_Fwd();
delay(10);
void go_Left() {
movement_Inst_Lft();
delay(10);
void go_Right() {
movement_Inst_Rgt();
delay(10);
void go_Backward(){
movement_Inst_Bwd();
delay(10);
void go_Stop(){
movement_Inst_Stp();
delay(10);
* These movement instruction are repeated several times in the code
void movement_Inst_Fwd(void){
Serial.println("Going_Forward");
// forward movement instructions
digitalWrite(LM_IN1,HIGH);
digitalWrite(LM_IN2,LOW);
digitalWrite(RM_IN3,HIGH);
digitalWrite(RM_IN4,LOW);
void movement_Inst_Lft(void){
Serial.println("Going_Left");
// Left movement instructions
digitalWrite(LM_IN1,LOW);
delay(500);
digitalWrite(RM_IN3,LOW);
delay(500);
void movement_Inst_Rgt(void){
Serial.println("Going_Right");
// Rgt movement instructions
delay(500);
delay(500);
void movement_Inst_Bwd(void){
Serial.println("Going_Backward");
// Bwd movement instructions
digitalWrite(LM_IN2,HIGH);
digitalWrite(RM_IN4,HIGH);
void movement_Inst_Stp(void){
Serial.println("Stopping");
// Stp movement instructions
