This is my first time using the forum, sorry if my way of asking is not too proper.
Iam trying to read from this register 0x7c in VL6180X time of flight sensor. I found this block of code that can be used to do that.
// Reads a 32-bit register
uint32_t VL6180X::readReg32Bit(uint16_t reg)
uint32_t value;
Wire.beginTransmission(address);
Wire.write((reg >> 8) & 0xff); // reg high byte
Wire.write(reg & 0xff); // reg low byte
last_status = Wire.endTransmission();
Wire.requestFrom(address, (uint8_t)4);
value = (uint32_t)Wire.read() << 24; // value highest byte
value |= (uint32_t)Wire.read() << 16;
value |= (uint16_t)Wire.read() << 8;
value |= Wire.read(); // value lowest byte
return value;
However when i put it in my arduino code, it keep giving the error below. And the error is from this line of code.
qualified-id in declaration before '(' token
Below is my arduino code
The range readings are in units of mm. */
#include <Wire.h>
#include <VL6180X.h>
VL6180X sensor;
void setup()
Serial.begin(9600);
Wire.begin();
sensor.init();
sensor.configureDefault();
sensor.writeReg(VL6180X::SYSRANGE__MAX_CONVERGENCE_TIME, 30);
sensor.writeReg16Bit(VL6180X::SYSALS__INTEGRATION_PERIOD, 50);
sensor.setTimeout(500);
// stop continuous mode if already active
sensor.stopContinuous();
// in case stopContinuous() triggered a single-shot
// measurement, wait for it to complete
delay(300);
// start interleaved continuous mode with period of 100 ms
sensor.startInterleavedContinuous(100);
//Reads a 32-bit sensor register and returns the value read.
//uint32_t readReg32Bit(uint16_t reg)
uint32_t value;
Wire.beginTransmission(0x7c);
Wire.requestFrom(0x7c, (uint8_t)4);
return value;
void loop()
Serial.print("Ambient: ");
Serial.print(sensor.readAmbientContinuous());
if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
Serial.print("\tRange: ");
Serial.print(sensor.readRangeContinuousMillimeters());
Serial.println();
please whats the proper way to implement this, or any other way to read from the register.
Thank you.
