I am trying to replace a 3 way switch with 2 Pololu Low Side Mosfet RC switches. I have the switches wired to the RC RX and have tested with a small motor and all is well.
I am trying to replace a handheld 3 way switch for a winch. One end of the switch is IN and one is OUT. Going into the switch are 3 wires. One +voltage and two that receive voltage depending on the switch state, either in or out. Those wires go into a relay box. I can’t get into the relay box because it is sealed with epoxy. Here is my sorta rough diagram.
So I am looking for the RC switch to just provide volts to it’s respective wire in place of the manual rocker switch. I have tried just about every combo of load, and power on the RC switch with no dice. Any idea what I am doing wrong?
