I’ve been looking for a reliable means to switch on/off a small 6 - 8 volt brushless cooling fan (2 pin) on an RC vehicle, from my transmitter, and at first glance the RC Switch Medium Low-Side MOSFET seemed that it would fit the bill… but I’m ignorant with anything electrically complicated, as I realized as I started to read the manual. Is it possible, at least easily, to run the Pololu RC Switch from a 6 volt supply to turn on/off a small brushless fan? I would run signal to a spare channel on the Rx, in the RC vehicle. I can tap into power from either the Rx or an additional BEC.
I have a simple PWM switch that I can control lights, but wasn’t sure if putting a motor on it would be ideal. That device is as simple as it gets. The Pololu is far more complicated than I realized.
Thanks for any feedback.
