Hi I am extremely new to electronics and learning the craft. I have installed a RC Switch and am getting 2 constant red lights on the LED indicators. I have double checked the voltage (5V through the reciever), double checked the wiring is correct. When the switch on the transmitter is put in the on position the switch can be heard on. I have read through the manual but there is no mention of a constant LED on. Thanks for any help.
Hello, Jade.
Unfortunately, from your picture, it looks like you are using one of our Basic SPDT Relay Carriers, which are activated by a simple digital high signal. If you are using RC servo signals as an input, you should instead be using one of our RC Switches with Relay.
Thanks for the prompt response.
