I’ve modified the wireless_adc_tx and rx apps to (1) use RadioLink instead of RadioQueue and (2) transmit a set of 8-bit integers instead of the serial number. For some reason, the last integer output to the COM port does not match the value I set in the source code - i.e., txPacket[4] does not match rxPacket[4]. Every other value matches as expected, and I haven’t been able to parse out a pattern (setting it to “3” in tx results in “0” on the terminal, “23” → “0”, “4” → “2”, etc). Any troubleshooting tips would be helpful!
EDIT: Now, no matter the value of txPacket[4], the terminal output shows “03”.
TX CODE
void adcToRadioService()
static uint16 lastTx = 0;
uint8 XDATA * txPacket;
// Check to see if it is time to send a report and
// if there is a radio TX buffer available.
if ((uint16)(getMs() - lastTx) >= param_report_period_ms && (txPacket = radioLinkTxCurrentPacket()))
// Both of those conditions are true, so send a report.
uint8 i;
uint16 XDATA * ptr = (uint16 XDATA *)&txPacket[5];
// This should be done before all the ADC readings, which take about 3 ms.
lastTx = getMs();
// Byte 0 is the length.
txPacket[0] = 16;
// Bytes 1-4 are the serial number. MODIFIED
txPacket[1] = 1;
txPacket[2] = 2;
txPacket[3] = 3;
txPacket[4] = 4; //TERMINAL OUTPUT (RX CODE) NEVER MATCHES THIS VALUE
adcSetMillivoltCalibration(adcReadVddMillivolts());
// Bytes 5-16 are the ADC readings on channels 0-6.
for (i = 0; i < 6; i++)
*(ptr++) = adcConvertToMillivolts(adcRead(i));
radioLinkTxSendPacket(0);
RX CODE
void radioToUsbService()
uint8 XDATA * rxPacket;
// Check if there is a radio packet to report and space in the
// USB TX buffers to report it.
if ((rxPacket = (uint8 XDATA *)radioLinkRxCurrentPacket()) && usbComTxAvailable() >= 64)
// We received a packet from a Wixel, presumably one running
// the wireless_adc_tx app. Format it nicely and send it to
// the USB host (PC).
uint8 i;
uint16 XDATA * ptr_16bit = (uint16 XDATA *)&rxPacket[5];
printf("%02d-%02d-%02d-%02d-%02d %5u",
rxPacket[0],
rxPacket[1],
rxPacket[2],
rxPacket[3],
rxPacket[4], //THIS VALUE IS NOT MATCHING txPacket[4] IN THE TX CODE
(uint16)getMs()
for(i = 0; i < 6; i++)
printf(" %5u", *(ptr_16bit++));
putchar('\r');
putchar('\n');
radioLinkRxDoneWithPacket();
TERMINAL OUTPUT
