I have an application where I am operating a Wild Thumper 100’ away in a thick walled steel tank. My concern is my Spectrum DXi Radio will not be able to control the vehicle in the steel tank.
Does anybody have any suggestions on a wired controller or alternative solution?
Here’s a novel idea use the steel tank as the arial for the receiver.
Or make a trig station from outside to inside using another set of tranemiter / reciever.
They may have to be a different frequence.
You should look at some sort of repeater. If the rover sits inside a steel tank the RF signal would likely not reach inside; so you need to relay that RF link into the tank.
