Hi there:
My questions are about Pololu Pushbutton Power Switch LV. I need to achieve the following:
- The device must be turned ON automatically when the power is applied (without need of pressing the push button).
- The device must be turned OFF when a high level is applied tu OFF pin.
Can reach the point above by shorting the two push button pins?.
- Does it have reverse protection?. The voltage difference beetwin In and Out cold be as high as 2 volts more in the OUT than the IN, when de device is turned off.
Many thanks for your help.
