I am embarrassed that I’m asking this, but I’m kinda at wits end. I’ve had these magnetic encoders work before in a different project. I thought I knew what I was doing. I’ve stripped this down to its bare minimum, which suggests that I’m doing something obviously dumb.
I have the encoders on a micrometal gear motor. They’re wired up:
ground to ground
VCC to 5v
A to an Uno Pin 2
B to Uno Pin 3
I need to take things apart to make sure I haven’t soldered something weird but… it should be super simple, right? As I manually spin the motor, it should increase rightCount. But it’s not changing.
To make sure things are working on the Uno and with the interrupt, I rigged up a button instead of the encoders and it works fine.
I’ve tried the pins as both input and input_pullup — when it’s input, it runs wild even when the wheel doesn’t move.
I’ve tried it with two different encoders with the same issue — it’s not changing so.
Thanks in advance,
-Thom
volatile unsigned long rightCount;
void setup() {
Serial.begin(9600);
Serial.print("Hello World.");
pinMode(2,INPUT_PULLUP);
pinMode(3,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2),right,CHANGE);
attachInterrupt(digitalPinToInterrupt(3),right,CHANGE);
void loop() {
Serial.print("Count Right:\t"); Serial.println(rightCount);
void right() {
rightCount++;
