Actually , I have been since two weeks looking for convinced and final solution for my problem , actually I am completely lost , I am working on mobile robot (Rover 5) with 2 motors , 2 encoders . the controller that designed to the robot needs to know the odometery of mobile robot (X ,Y, Heading Angle ) , actually I am trying to function the encoders for this purpose , getting X ,Y, Heading Angle by measuring the traveled distance by each wheel , so to get the X ,Y, Heading Angle values , I should compute a accurate readings without missing any counts or ticks as could as possible .
The problem now is :
In the code in the attachment , while I am testing the encoders counts , I noticed that there is a difference between counts of encoders even when they spin in the same constant speed (PMW) , the difference increases as the two motors continue . so I thought that is the main cause of inaccurate odometery results .
In the output of the code (in the attachment also) the first two columns are right and left motors speed , the third & forth columns are right and left encoder counts , the fifth column is the difference between two encoders count , as you could see ,that even when the speed of two motors are approximately the same (each motor feed up with 100 PWM) there is a difference in the encoder counts and as you could see that the difference become big and big as the motors continuing spin .
One thing I thought that sending the same PWM value to two different motors will almost never produce the exact same speed , so I think that I should detect the absolute motion of the motors and adjust the power to get the speed/distance , but when I test the speed of motors after feed them with 100 PWM at same time , the two speeds were almost identical , but I noticed that there is a difference between counts of two encoders even when the motors spin in the same constant speed .
Actually , I don’t know where is the problem , Is it in the code ? Is it in the hardware ? or what ? I am completely lost , I need for patient someone to help
Thanks alot
Attachments contain Arduino Files .
Encoder_ino.ino (4.07 KB)
output.ino (28.7 KB)
