Will any of your reflectance sensors work well for robot line/grid following outdoors in bright sunlight?
Unfortunately, I do not expect any of our QTR sensors to work well under direct bright sunlight. Sunlight has quite a bit of IR, which can easily flood the sensor. You might be able to get something to work if you can shield the area around (and below) the sensor well enough.
