#include <AFMotor.h> //Adafruit Motor Shield Library. First you must download and install AFMotor library
#include <QTRSensors.h> //Pololu QTR Sensor Library. First you must download and install QTRSensors library
AF_DCMotor motor1(1, MOTOR12_1KHZ ); //create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor2(2, MOTOR12_1KHZ ); //create motor #2 using M2 output on Motor Drive Shield, set to 1kHz PWM frequency
#define KP 2 //experiment to determine this, start by something small that just makes your bot follow the line at a slow speed
#define KD 5 //experiment to determine this, slowly increase the speeds and adjust this value. ( Note: Kp < Kd)
#define M1_minumum_speed 150 //minimum speed of the Motor1
#define M2_minumum_speed 150 //minimum speed of the Motor2
#define M1_maksimum_speed 250 //max. speed of the Motor1
#define M2_maksimum_speed 250 //max. speed of the Motor2
#define MIDDLE_SENSOR 4 //number of middle sensor used
#define NUM_SENSORS 7 //number of sensors used
#define TIMEOUT 2500 //waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN QTR_NO_EMITTER_PIN //emitterPin is the Arduino digital pin that controls whether the IR LEDs are on or off. Emitter is controlled by digital pin 2
#define DEBUG 0
//sensors 0 through 5 are connected to analog inputs 0 through 5, respectively
QTRSensorsRC qtrrc((unsigned char[]){ 2, A5, A4, A3, A2, A1, A0} , NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
//unsigned char white_line=1;
void setup()
delay(1500);
manual_calibration();
set_motors(0, 0);
int lastError = 0;
int last_proportional = 0;
int integral = 0;
void loop()
unsigned int sensors[7];
int position = qtrrc.readLine(sensors); //get calibrated readings along with the line position, refer to the QTR Sensors Arduino Library for more details on line position.
int error = position - 3000;
int motorSpeed = KP * error + KD * (error - lastError);
lastError = error;
int leftMotorSpeed = M1_minumum_speed + motorSpeed;
int rightMotorSpeed = M2_minumum_speed - motorSpeed;
// set motor speeds using the two motor speed variables above
set_motors(leftMotorSpeed, rightMotorSpeed);
void set_motors(int motor1speed, int motor2speed)
if (motor1speed > M1_maksimum_speed ) motor1speed = M1_maksimum_speed;
if (motor2speed < M2_maksimum_speed ) motor2speed = M2_maksimum_speed;
if (motor1speed < 0) motor1speed = 0;
if (motor2speed < 0) motor2speed = 0;
motor1.setSpeed(motor1speed);
motor2.setSpeed(motor2speed);
motor1.run(FORWARD);
motor2.run(FORWARD);
//calibrate for sometime by sliding the sensors across the line, or you may use auto-calibration instead
void manual_calibration() {
int i;
for (i = 0; i < 250; i++)
qtrrc.calibrate(QTR_EMITTERS_ON);
delay(20);
if (DEBUG) {
Serial.begin(9600);
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.println();
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
Serial.println();
Serial.println();
To follow a white line on a black background using the Arduino library for the Pololu QTR reflectance sensors, you should use the QTRSensors::readLineWhite()
method. You can find more details about that function in the library’s documentation, which is linked near the bottom on the QTRSensors library’s page.
- Amanda
#define KP 2
#define KD 5
#define KP1 2
#define KD1 5
#define M1_minumum_speed 255 //minimum speed of the Motor1
#define M2_minumum_speed 255 //minimum speed of the Motor2
#define M1_maksimum_speed 255 //max. speed of the Motor1
#define M2_maksimum_speed 255 //max. speed of the Motor2
#define MIDDLE_SENSOR 3,4 //number of middle sensor used
#define NUM_SENSORS 6 //number of sensors used
#define DEBUG 0
QTRSensorsRC qtrrc((unsigned char[]) {
void setup()
delay(1500);
set_motors(0, 0);
int lastError = 0;
int integral = 0;
int lastError1 = 0;
int last_proportional1 = 0;
int integral1 = 0;
void loop()
unsigned int sensors[6];
for(int i;i=1;i<1000000000000){
if (int position = qtrrc.readLine(sensors, QTR_EMITTERS_ON, 1)) {
int error = position - 2000;
lastError = error;
break;
else if (int position = qtrrc.readLine(sensors)) {
int error1 = position - 2000;
int motorSpeed = KP1 * error1 + KD1 * (error1 - lastError1);
lastError1 = error1;
break;
if (motor2speed > M2_maksimum_speed ) motor2speed = M2_maksimum_speed;
int i;
delay(20);
if (DEBUG) {
Serial.begin(9600);
Serial.print(' ');
Serial.println();
Serial.print(' ');
Serial.println();
Serial.println();
