I need your Guidance.
I am using Pololu QTR-8RC (all 8 sensors) sensor for line follower robot. I have tested my robot for line width of 15-20mm in which line just fits in the distance between two sensors. I used the Position reading of the sensor to calculate my Error value and then obtained the motor speeds using PID calculation.
But now I want my robot to follow the Line of width of 30-35mm. Here, in the desired position, the central three sensors are on the line at the same time. So, in this scenario, Will the position reading from the sensor be accurate and Can I use this reading to calculate my error and Motor Speeds?.
Thanks for your reply.
I have not tried my robot as of now on course with wider lines but I plan to do so.
But I am confused as to what will be the Position reading from the sensor when line is below any three sensors at the same time?
Because I think the Position reading indicatesââBetween which sensors the line isâ. For e.g: If the position is 3500, then the line is exactly in the middle of 3&4 sensor. But if the line is under three sensors at the same time, then what will the position reading be and will it be accurate?
The position value is a weighted average of the position times 1000, so if the line was being seen by 3 sensors equally, the value reported would be the middle sensor of those three sensors multiplied by 1000. You can see more about this in the âQTRSensors Methods & Usage Notesâ section of the âArduino Library for the Pololu QTR Reflectance Sensorsâ documentation.
