I am designing the servo drive circuit for HD1235MG.
I would like to know the Voltage level for the PWM input of HD1235MG.
Can I connect the PWM output from 3.3V MCU directly to the HD1235MG ?
Also, Provide the Interface connector pin details for HD1235MG.
Best Regards Siva
Hello Siva.
Unfortunately, most servo manufacturers (including Power HD) do not specify the signal voltage ranges, but I just tested a 3.3 V PWM signal on a HD-1235MG servo here and it worked. I would expect a PWM output from your 3.3 V MCU to work as well.
The connector is a female JR style connector. You can find information about the connector’s pinout from the FAQs tab on the product page.
-Patrick
Thanks Patrick
