OK, I think I’ve got it sorted for the Mega on pins 3 & 5, but this same library wont work with both Mega and other boards. Someone that knows more about compiler directives may be able to sort it.
Here is the code that works with the Mega:
DualVNH5019MotorShield.h
#ifndef DualVNH5019MotorShield_h
#define DualVNH5019MotorShield_h
#include <Arduino.h>
class DualVNH5019MotorShield
public:
// CONSTRUCTORS
DualVNH5019MotorShield(); // Default pin selection.
DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
unsigned char INA2, unsigned char INB2, unsigned char EN2DIAG2, unsigned char CS2); // User-defined pin selection.
// PUBLIC METHODS
void init(); // Initialize TIMER 1 (or timer 3 for mega) set the PWM to 20kHZ.
void setM1Speed(int speed); // Set speed for M1.
void setM2Speed(int speed); // Set speed for M2.
void setSpeeds(int m1Speed, int m2Speed); // Set speed for both M1 and M2.
void setM1Brake(int brake); // Brake M1.
void setM2Brake(int brake); // Brake M2.
void setBrakes(int m1Brake, int m2Brake); // Brake both M1 and M2.
unsigned int getM1CurrentMilliamps(); // Get current reading for M1.
unsigned int getM2CurrentMilliamps(); // Get current reading for M2.
unsigned char getM1Fault(); // Get fault reading from M1.
unsigned char getM2Fault(); // Get fault reading from M2.
private:
unsigned char _INA1;
unsigned char _INB1;
#if defined(__AVR_ATmega168__)|| defined(__AVR_ATmega328P__)
static const unsigned char _PWM1 = 9;
static const unsigned char _PWM2 = 10;
#endif
#if defined(__AVR_ATmega128__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
static const unsigned char _PWM1 = 3;
static const unsigned char _PWM2 = 5;
#endif
unsigned char _EN1DIAG1;
unsigned char _CS1;
unsigned char _INA2;
unsigned char _INB2;
unsigned char _EN2DIAG2;
unsigned char _CS2;
#endif
DualVNH5019MotorShield.cpp
#include "DualVNH5019MotorShield.h"
// Constructors ////////////////////////////////////////////////////////////////
DualVNH5019MotorShield::DualVNH5019MotorShield()
//Pin map
_INA1 = 2;
_INB1 = 4;
_EN1DIAG1 = 6;
_CS1 = A0;
_INA2 = 7;
_INB2 = 8;
_EN2DIAG2 = 12;
_CS2 = A1;
DualVNH5019MotorShield::DualVNH5019MotorShield(unsigned char INA1, unsigned char INB1, unsigned char EN1DIAG1, unsigned char CS1,
//Pin map
//PWM1 and PWM2 cannot be remapped because the library assumes PWM is on timer1
_INA1 = INA1;
_INB1 = INB1;
_EN1DIAG1 = EN1DIAG1;
_CS1 = CS1;
_INA2 = INA2;
_INB2 = INB2;
_EN2DIAG2 = EN2DIAG2;
_CS2 = CS2;
// Public Methods //////////////////////////////////////////////////////////////
void DualVNH5019MotorShield::init()
// Define pinMode for the pins and set the frequency for timer1.
pinMode(_INA1,OUTPUT);
pinMode(_INB1,OUTPUT);
pinMode(_PWM1,OUTPUT);
pinMode(_EN1DIAG1,INPUT);
pinMode(_CS1,INPUT);
pinMode(_INA2,OUTPUT);
pinMode(_INB2,OUTPUT);
pinMode(_PWM2,OUTPUT);
pinMode(_EN2DIAG2,INPUT);
pinMode(_CS2,INPUT);
// Timer 1 configuration
// prescaler: clockI/O / 1
// outputs enabled
// phase-correct PWM
// top of 400
// PWM frequency calculation
// 16MHz / 1 (prescaler) / 2 (phase-correct) / 400 (top) = 20kHz
TCCR1A = 0b10100000;
TCCR1B = 0b00010001;
ICR1 = 400;
#endif
// Mega board specific stuff here - assumes assigning timer3, using pins 3 &5
TCCR3A = 0b10100000; // Mega pin 5
TCCR3B = 0b00010001; // Mega pin 3
ICR3 = 400;
#endif
// Set speed for motor 1, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM1Speed(int speed)
unsigned char reverse = 0;
if (speed < 0)
speed = -speed; // Make speed a positive quantity
reverse = 1; // Preserve the direction
if (speed > 400) // Max PWM dutycycle
speed = 400;
OCR1A = speed;
#elseif defined(__AVR_ATmega128__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
OCR3A = speed;
#else
analogWrite(_PWM1,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (reverse)
digitalWrite(_INA1,LOW);
digitalWrite(_INB1,HIGH);
digitalWrite(_INA1,HIGH);
digitalWrite(_INB1,LOW);
// Set speed for motor 2, speed is a number betwenn -400 and 400
void DualVNH5019MotorShield::setM2Speed(int speed)
if (speed < 0)
speed = -speed; // make speed a positive quantity
reverse = 1; // preserve the direction
speed = 400;
OCR1B = speed;
OCR3C = speed;
#else
analogWrite(_PWM2,speed * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
if (reverse)
digitalWrite(_INA2,LOW);
digitalWrite(_INB2,HIGH);
digitalWrite(_INA2,HIGH);
digitalWrite(_INB2,LOW);
// Set speed for motor 1 and 2
void DualVNH5019MotorShield::setSpeeds(int m1Speed, int m2Speed)
setM1Speed(m1Speed);
setM2Speed(m2Speed);
// Brake motor 1, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM1Brake(int brake)
// normalize brake
if (brake < 0)
brake = -brake;
if (brake > 400) // Max brake
brake = 400;
digitalWrite(_INA1, LOW);
digitalWrite(_INB1, LOW);
OCR1A = brake;
OCR3A = brake;
#else
analogWrite(_PWM1,brake * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
// Brake motor 2, brake is a number between 0 and 400
void DualVNH5019MotorShield::setM2Brake(int brake)
// normalize brake
if (brake < 0)
brake = -brake;
brake = 400;
digitalWrite(_INA2, LOW);
digitalWrite(_INB2, LOW);
OCR1B = brake;
OCR3C = brake;
#else
analogWrite(_PWM2,brake * 51 / 80); // default to using analogWrite, mapping 400 to 255
#endif
// Brake motor 1 and 2, brake is a number between 0 and 400
void DualVNH5019MotorShield::setBrakes(int m1Brake, int m2Brake)
setM1Brake(m1Brake);
setM2Brake(m2Brake);
// Return motor 1 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM1CurrentMilliamps()
// 5V / 1024 ADC counts / 144 mV per A = 34 mA per count
return analogRead(_CS1) * 34;
// Return motor 2 current value in milliamps.
unsigned int DualVNH5019MotorShield::getM2CurrentMilliamps()
return analogRead(_CS2) * 34;
// Return error status for motor 1
unsigned char DualVNH5019MotorShield::getM1Fault()
return !digitalRead(_EN1DIAG1);
// Return error status for motor 2
unsigned char DualVNH5019MotorShield::getM2Fault()
return !digitalRead(_EN2DIAG2);
Here is my attempt to have a single library that works with Uno/Duemilenova and Mega:
The problem is that only one channel lights up, pin 5 gets pwm, but pin 3 doesn’t. I’ve run out of time to get this working ‘universally’, I just have to run with 2 versions of the library (the original and the one above).
Would love to see someone solve this.
//Pin map
_INA1 = 2;
_INB1 = 4;
_EN1DIAG1 = 6;
_CS1 = A0;
_INA2 = 7;
_INB2 = 8;
_EN2DIAG2 = 12;
_CS2 = A1;
//Pin map
_INA1 = INA1;
_INB1 = INB1;
_CS1 = CS1;
_INA2 = INA2;
_INB2 = INB2;
_CS2 = CS2;
// outputs enabled
// top of 400
ICR1 = 400;
#endif
ICR3 = 400;
#endif
if (speed < 0)
speed = 400;
OCR1A = speed;
#if defined(OCR3A)//
OCR3A = speed;
#endif
#else
#endif
if (reverse)
if (speed < 0)
speed = 400;
OCR1B = speed;
#if defined OCR3C
OCR3C = speed;
#endif
#else
#endif
if (reverse)
// normalize brake
if (brake < 0)
brake = -brake;
brake = 400;
OCR1A = brake;
#if defined OCR3A
OCR3A = brake;
#endif
#else
#endif
// normalize brake
if (brake < 0)
brake = -brake;
brake = 400;
OCR1B = brake;
#if defined OCR3C
OCR3C = brake;
#endif
#else
#endif
