HI all! Rather basic question here, I searched the forum but that did not turn up an answer.
I have a 7.4V LiPo --> S9V11F5S6CMA 5V regulator --> Arduino 5V pin.
Note that I connect to the Arduino’s 5V pin directly so I can bypass the Arduino’s very inefficient internal linear regulator. This does mean though, that I must make sure I never put anything above 5V on that pin or I’d fry the Arduino’s microcontroller.
As for the Arduino itself, it’s an AtMega microcontroller so it’s happy being switched on/off by simply having 0V or 5V on its 5V pin. But never more than 5V, or the magic smoke escapes.
The question is: what is the correct (safe) way to power on/off this circuit? Can I just have a open/close switch in the 7.4V line from the LiPo to the Pololu regulator Vin? Does the Pololu regulator make sure I don’t get anything above 5V on its Vout during power-up and power-down? Or do I need a more fancy solution?
Note that I don’t want to simply put a switch in the 5V to the Arduino because that way the regulator would still drain the LiPo quite fast with its 1mA no-load current (it’s a really tiny LiPo).
Thanks for your advice!
