I have this setup:
-Pololu 3pi with atmega328p
-Atmel studio 7 on Windows 7 (6.1.7601)
-Pololu USBAVR programmer
-the following error while compiling:
[code]------ Build started: Project: BLINK, Configuration: Debug AVR ------
Build started.
Project “BLINK.cppproj” (default targets):
Target “PreBuildEvent” skipped, due to false condition; (’$(PreBuildEvent)’!=’’) was evaluated as (’’!=’’).
Target “CoreBuild” in file “C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets” from project “C:\Users\rblore\code\Pololu 3pi Robot\BLINK.cppproj” (target “Build” depends on it):
Using “RunCompilerTask” task from assembly “C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll”.
Task "RunCompilerTask"
Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all
make: *** No rule to make target .././Sketch.cpp', needed by
Sketch.o’. Stop.
Done executing task “RunCompilerTask” – FAILED.
Done building target “CoreBuild” in project “Individual apps.cppproj” – FAILED.
Done building project “Individual apps.cppproj” – FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========[/code]
-and this code
/*Begining of Auto generated code by Atmel studio */
#include <Arduino.h>
/*End of auto generated code by Atmel studio */
//Beginning of Auto generated function prototypes by Atmel Studio
void setup();
void loop();
//End of Auto generated function prototypes by Atmel Studio
void setup() {
pinMode(10, OUTPUT);
pinMode(7, OUTPUT);
void loop() {
tone(10,3000,500);
digitalWrite(7, HIGH);
delay(1000);
digitalWrite(7, LOW);
delay(1000);
The file that needs to be sent to the flash won’t generate
