I have installed the Boards (ver 3.1.0) add-on into my Arduino IDE (V1.8.4).
It seems to be working correctly. However, the only extension that I have been able to guess is Serial1.
Can you point me to any documentation listing the other ATMEGA328PB/Arduinio extensions that may be included in your add-on.
For example how do I access the additional “328PB” GPIO PE3/PE2 (A6/A7)?
You can access the new pins PE0/SDA1, PE1/SCL1, PE2/A6, and PE3/A7 the same way you would access any other GPIO pins, using pinMode, digitalWrite, digitalRead, and analogRead (for the analog-capable pins). For more information, see the recently-added “ATmega328PB support in the Arduino IDE” section in the Pololu A-Star 328PB User’s Guide.
