Programming ATmega328P chip with USB AVR Programmer v2.1
I’m trying to program a bare ATMega328P chip using MiniCore and your USB AVR Progammer v2.1. I’m using the minimal wiring setup for DIP28 from MiniCore:
I’m trying to follow the programmer’s User Guide along with the config tool - when it’s connected to my Mac (macOS Sonoma, v14.6.1) I see a steady green light and quickly flashing yellow LEDs; after trying to Burn Bootloader the red light stays on.
I don’t see “Atmel STK500” listed under Programmer menu, but I do see “STK500 as ISP” The output in the Arduino IDE (v1.8.18):
Arduino: 1.8.18 (Mac OS X), Board: "ATmega328, Yes (UART0), EEPROM retained, Default, 328P / 328PA, BOD 2.7V, LTO enabled, External 16 MHz"
/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/bin/avrdude -C/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/etc/avrdude.conf -v -patmega328p -cstk500 -P /dev/cu.usbmodem002795022 -e -Ulock:w:0xff:m -Uefuse:w:0b11111101:m -Uhfuse:w:0xd7:m -Ulfuse:w:0b11110111:m
Avrdude version 8.0-arduino.1
Copyright see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is /Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/etc/avrdude.conf
User configuration file /Users/rwaddell/.avrduderc does not exist
Using port            : /dev/cu.usbmodem002795022
Using programmer      : stk500
Successfully opened stk500v2 device; in future
please use -c stk500v2, so -x parameters are available
AVR part              : ATmega328P
Programming modes     : SPM, ISP, HVPP, debugWIRE
Programmer type       : STK500V2
Description           : Atmel STK500 (probes v2 first then v1)
Programmer model      : STK500
HW version            : 15
FW Version Controller : 2.10
Topcard               : Unknown
Vtarget               : 4.9 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 0.5 us
XTAL frequency        : 7.372800 MHz
Error: command failed
Error: initialization failed  (rc = -1)
 - double check the connections and try again
 - use -B to set lower the bit clock frequency, e.g. -B 125kHz
 - use -F to override this check
Avrdude done.  Thank you.
Error while burning bootloader.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I don’t have any external power connected to the board - I thought if the Config tool has “VCC output = enabled” then that isn’t necessary, but I’m not sure.
EDIT: I added external 5V power supply but no change.
Can you post some pictures that show all of your physical connections? Your screenshot of the programmer utility indicates that there was no error in the “Results from last programming” box, but that does not make sense if the red LED is turning on, so I suspect you did not have that running while you were trying to actually program with the board. Can you try uploading your program with programmer configuration utility running and your Arduino IDE set up to show verbose output (you can enable verbose output from the “Preferences” menu under “File”) and post new screenshots/output-messages for those so we can see what is reported?
Also, if it is possible for you to test your programmer with another device that you know to be working (e.g. an Arduino in good condition), that would be a good baseline to establish that the programmer and the ISP cable are okay.
- Patrick
By the way, you have 128P in the title but 328P everywhere else. Can you clarify what microcontroller you are programming?
  • Typo - I’ve got a 328P chip
  • Programmer works fine with my Uno. I was able to upload a sketch (Blink)
  • 16Mhz External oscillator with 22pF capacitors
Config Utility when trying to burn bootloader:
HW version            : 15
Topcard               : Unknown
Vtarget               : 4.9 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 0.5 us
I don’t see the Atmel STK500 development board listed when using MiniCore:
If that is a brand new ATmega328P chip, then it is configured by the manufacturer to use the 8 MHz internal RC clock with divide by 8 set, so the MCU frequency is 1 MHz.
Consequently, the ISP programming clock frequency must be set to 250 kHz or less. The fuses need to be changed in order to use the external crystal oscillator.
I don’t see the required 100 nF decoupling caps on the breadboard.
I have one 0.1uF cap across pins 7 & 8; do I need another 0.1uF cap across pins 20 & 22?
Where do I set the ISP clock frequency in the Configurator - is it the ISP Frequency field?
Also, if I Burn Bootloader with Clock: 16Mhz External isn’t that setting the fuses as you say and then subsequent programming will work?
I just tried Sketch > Upload using Programmer and while that worked (avrdude reports no errors) the LED doesn’t flash.
void setup() {
  pinMode(7, OUTPUT);
// the loop function runs over and over again forever
void loop() {
  digitalWrite(7, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(7, LOW);    // turn the LED off by making the voltage LOW
Yes.
You can read out the fuses to check. Please state whether you started with a factory fresh chip.
I see “STK500 as ISP” in the list.
Yes, this is a bare 328 chip. I also have bare 328P chips.
How can I read the fuses? I just inserted a new bare chip and when I go Tools > Board Info I get this:
Screenshot 2025-07-25 at 11.22.00 AM
The only value below 250kHz in that field is 114kHz.
The question was: is it factory fresh? If so, the MCU clock is 1 MHz and you MUST choose the 114 kHz ISP frequency with that particular programmer.
I’ve put in a new, factory fresh 328 chip and was able to burn the bootloader after changing the ISP frequency to 114kHz:
/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/bin/avrdude -C/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/etc/avrdude.conf -v -patmega328 -cstk500 -P /dev/cu.usbmodem002795022 -e -Ulock:w:0xff:m -Uefuse:w:0b11111101:m -Uhfuse:w:0xd7:m -Ulfuse:w:0b11110111:m
HW version            : 15
Topcard               : Unknown
Vtarget               : 4.9 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 8.7 us
AVR device initialized and ready to accept instructions
Device signature = 1E 95 14 (ATmega328)
Erased chip
Processing -U lock:w:0xff:m
Reading 1 byte for lock from input file 0xff
in 1 section [0, 0]
/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/bin/avrdude -C/Users/rwaddell/Library/Arduino15/packages/MiniCore/tools/avrdude/8.0-arduino.1/etc/avrdude.conf -v -patmega328 -cstk500 -P /dev/cu.usbmodem002795022 -Uflash:w:/Users/rwaddell/Library/Arduino15/packages/MiniCore/hardware/avr/3.1.1/bootloaders/urboot/atmega328/watchdog_1_s/autobaud/uart0_rxd0_txd1/led+b5/urboot_atmega328_pr_ee_ce.hex:i -Ulock:w:0xff:m
Writing 1 byte (0xFF) to lock, 1 byte written, 1 verified
Processing -U efuse:w:0b11111101:m
Reading 1 byte for efuse from input file 0b11111101
in 1 section [0, 0]
Writing 1 byte (0xFD) to efuse, 1 byte written, 1 verified
Processing -U hfuse:w:0xd7:m
Reading 1 byte for hfuse from input file 0xd7
in 1 section [0, 0]
Writing 1 byte (0xD7) to hfuse, 1 byte written, 1 verified
Processing -U lfuse:w:0b11110111:m
Reading 1 byte for lfuse from input file 0b11110111
in 1 section [0, 0]
Writing 1 byte (0xF7) to lfuse, 1 byte written, 1 verified
HW version            : 15
Topcard               : Unknown
Vtarget               : 4.9 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 8.7 us
Auto-erasing chip as flash memory needs programming (-U flash:w:...)
specify the -D option to disable this feature
Erased chip
Processing -U flash:w:/Users/rwaddell/Library/Arduino15/packages/MiniCore/hardware/avr/3.1.1/bootloaders/urboot/atmega328/watchdog_1_s/autobaud/uart0_rxd0_txd1/led+b5/urboot_atmega328_pr_ee_ce.hex:i
Reading 384 bytes for flash from input file urboot_atmega328_pr_ee_ce.hex
in 1 section [0x7e80, 0x7fff]: 3 pages and 0 pad bytes
Writing 384 bytes to flash
Writing | ################################################## | 100% 0.14s
Reading | ################################################## | 100% 0.13s
384 bytes of flash verified
in 1 section [0, 0]
So: do I try uploading the Blink sketch using (a) Upload button on the toolbar, or (b) Sketch > Upload using Programmer? I’m still connected to the chip via ISP.
The entire point of the bootloader is that it allows you to program the chip using a PC to Arduino serial port connection, which is a much simpler connection.
If you upload a program to an AVR chip using an ISP programmer, the bootloader is usually (if not always) erased. The advantage there is freeing up memory for more program code.
I get that, but does using Sketch > Upload using Programmer also blow away the config settings along with the bootloader?
Uploading code using an ISP programmer should not alter the fuse settings, although the option to do so exists.
I don’t recommend that approach to beginners unless the project code requires the additional memory made available by erasing the bootloader.
I’ve uploaded the Blink sketch using UART and while there are no errors, the LED doesn’t blink. But I am getting serial monitor info:
void setup() {
  pinMode(7, OUTPUT);
  Serial.begin(9600);
void loop() {
  Serial.println("LED is on");
  Serial.println("LED is off");
LED is on
LED is off
LED is on
LED is off
LED is on
LED is off
Wiring problem, bad or incorrectly oriented LED, etc.
LED works, 330R connected to +ve lead from pin #13 (PD7, Arduino digital pain 7), -ve lead to GND.
You have a mystery to solve. Have fun!
Thank you @Jim_Remington for jumping into the thread!
@RossW, I updated the thread name to avoid confusion for other readers. I’m glad to see that you are able to successfully upload code to your controller now. I suggest that you disconnect the LED from your circuit and check what your pin is doing with a multimeter when you run your code. If it’s switching and you already confirmed the LED works, then the issue is most likely related to your connections. Maybe some of the breadboard rows are damaged, and you might check if the power rails are connected along the full length of the breadboard. We have seen some where the break in the red and blue lines (circled in yellow below) indicate a break between rails.
Otherwise, the most likely cause is the microcontroller (maybe just that individual pin) is somehow damaged.
- Patrick
Holy toast - it would’ve taken me forever to work out the break in the power rails. Everything works as expected now.
Thank you so much Patrick and Jim for helping me out with this!
