Hey Folks –
I just got a Micro Maestro servo controller and I’ve been trying to get it to work with my Arduino Uno.
I’m trying to use SoftSerial library. I’ve read though this forum and found lots of example code, however, I’ve never gotten any of it to work.
I can directly control the servo with the USB and Polou control program so I know the controller and servo are working.
I’ve got 4AA batteries hooked up to the controller and I’ve attached it to the positive rail of the servo with a wire on the back, as described in the docs.
I’ve got all the grounds hooked up together.
I’ve got the controllers RX pin hooked up to the defined TX pin (4) and vice versa.
I’ve got one servo on chan 0.
I’ve bee focusing on this bit of code:
// Pololu micro serial servo controller modes
// Software Serial from Arduino example by Tom Igoe
// put() (now position_absolute) & set_speed() functions found on pololu forums & modified
// mike crist 2009-01-03
#include <SoftwareSerial.h>
#define rxPin 3
#define txPin 4
// set up a new serial port
SoftwareSerial softSerial = SoftwareSerial(rxPin, txPin);
void setup()
pinMode(rxPin, INPUT);
digitalWrite(txPin, HIGH); // keeps pololu board from getting spurious signal
pinMode(txPin, OUTPUT);
// set the data rate for the SoftwareSerial port
softSerial.begin(9600);
set_speed(0, 0);
void loop()
position_absolute(0, 1000);
delay(500);
position_absolute(0, 3000);
void position_absolute(byte servo, int angle)
//this function uses pololu mode command 4 to set absolute position
//servo is the servo number (typically 0-7)
//angle is the absolute position from 500 to 5500
unsigned int temp;
byte pos_hi,pos_low;
temp = angle & 0x1f80; //get bits 8 thru 13 of position
pos_hi = temp >> 7; //shift bits 8 thru 13 by 7
pos_low = angle & 0x7f; //get lower 7 bits of position
//Send a Pololu Protocol command
softSerial.print(0x80, BYTE); //start byte
softSerial.print(0x01, BYTE); //device id
softSerial.print(0x04, BYTE); //command number
softSerial.print(servo, BYTE); //servo number
softSerial.print(pos_hi, BYTE); //bits 8 thru 13
softSerial.print(pos_low, BYTE); //bottom 7 bits
void set_speed(byte servo, byte speedVal)
//this function uses pololu mode command 1 to set speed
//speedVal is servo speed (1=slowest, 127=fastest, 0=full)
//set speedVal to zero to turn off speed limiting
speedVal = speedVal & 0x7f; //take only lower 7 bits of the speed
softSerial.print(0x80,BYTE); //start byte
softSerial.print(0x01,BYTE); //device id
softSerial.print(0x01,BYTE); //command number
softSerial.print(servo,BYTE); //servo number
softSerial.print(speedVal,BYTE); //speed
And when I upload it to the Arduino nothing happens.
The yellow LED blinks twice ever second, & according to the docs:
"two flashes indicates that at least one of the servos is enabled or one of the output channels is being driven high
Any help would be great. Thanks!
