Hello to the community, after a while I make a new project with my 3pi, I see that my program does not stop flashing red light and did not recognize the connection. I have reinstalled but the problem continues, my system is Windows XP.
Someone knows why this happen?
Can you confirm which of our programmers you have? Is it our Orangutan USB programmer (with the code “PGM02” written on the bottom copper) or our USB AVR programmer (with the code “PGM03A” written on the bottom silkscreen)?
For both programmers, a flashing red LED means that the programmer is not detecting target power. Is your 3pi turned on when you’re trying to program it?
Has the programmer ever worked for you before, and if so, what happened between when it last worked and when it first stopped working? Do you have it plugged into your 3pi and is your 3pi turned on (i.e. do you see both blue power LEDs lit up on the 3pi)?
Yes, I was working normally on the same computer as 4 months, the 3pi catches normally but the USB Program keeps flashing red light goes off when I turn on the 3pi connected to it, but when compiling the program from AVR Studio I did not recognize.
I don’t understand what you mean by “the 3pi catches normally” or “but when compiling the program from AVR Studio I did not recognize”.
Does your 3pi appear to be functioning properly (e.g. is it still running the last program you put on it)? Please confirm that you see both blue LEDs light up when you turn the 3pi on, and please use a multimeter to verify that VCC on the 3pi is reading close to 5V.
The LCD is probably damaged, but I think there’s a good chance that the 3pi itself is okay. You should be able to fix it by replacing the LCD with a new one (you will also need to get special headers so that you can plug it into your 3pi’s LCD port).
I don’t know what is wrong with your programmer, but I suggest you get one of our newer (and much better) USB AVR programmers and see if that works for you. If you email us directly and mention this thread, we should at least be able to get you a discount on a new programmer.
