I’m a noob and i bricked my controller by uploading sketch with wrong board stings.
No virtual serial port, no led on the board
Now I’m trying to compile avrdude on debian buster
$ make
/bin/bash ./ylwrap config_gram.y y.tab.c config_gram.c y.tab.h `echo config_gram.c | sed -e s/cc$/hh/ -e s/cpp$/hpp/ -e s/cxx$/hxx/ -e s/c++$/h++/ -e s/c$/h/` y.output config_gram.output -- yacc -d
updating config_gram.h
/bin/bash ./ylwrap lexer.l .c lexer.c -- :
make: *** [Makefile:1924: lexer.c] Error 1
Any help on that error or where can I download binary of avrdude?
Nevermind. I was mising bison and flex packages.
Now I have problem with resetng the controler.
$ sudo avrdude -c avr109 -p atmega32U4 -P /dev/ttyACM0 -e
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.23s
avrdude: Device signature = 0x3f0d0d
avrdude: Expected signature for ATmega32U4 is 1E 95 87
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Do I have to reflash the bootloader?
