Hardware:
I have a A-star 32U4 SV (item #: 3115) and am using the external pololu programmer v2 (item #: 3170).
Setup:
I’m using atmel studio 7 (7.0.1006). To create my project I use the “Create project from Arduino sketch” option and choose “Arduino Leonardo” as my board. I also use the “Bottons.ino” example sketch from the A-Star 32U4 Arduino library. I then add the A-Star 32U4 Arduino library in the solution explorer and add the library directory as an “include path” in the “toolchain” setup.
Problem:
I change the example code a bit as shown in the following:
#include <AStar32U4.h>
AStar32U4LCD lcd;
AStar32U4ButtonA buttonA;
int main()
lcd.clear();
lcd.print("Prs BtnA");
while (1)
if (buttonA.getSingleDebouncedPress())
// blink LED
ledGreen(1);
delay(200);
ledGreen(0);
The code compiles fine and the controller is programmed without any problems. The controller displays to the LCD “Prs BtnA”, but when I press button A nothing happens. I think the problem is with the function “getSingleDebouncedPress()” and here’s why…
When I compile and program the following code to the controller there are no errors.
int main(void)
// Turn the LEDs on.
ledRed(1);
ledYellow(1);
ledGreen(1);
// Wait for a second.
delay(1000);
// Turn the LEDs off.
ledRed(0);
ledYellow(0);
ledGreen(0);
delay(1000);
But the LEDs just turn on and stay on. The controller seems to “freeze” when it gets the “delay()” function. So I changed the “delay()” function to “_delay_ms()
” (which is just avr-libc function) as shown in the following:
int main(void)
ledRed(1);
ledYellow(1);
ledGreen(1);
_delay_ms(1000);
ledRed(0);
ledYellow(0);
ledGreen(0);
_delay_ms(1000);
and the program runs fine; the LEDs flash. My guess is the function “getSingleDebouncedPress()” uses the “delay()” function.
The Question:
Does any know why the “getSingleDebouncedPress()” and “delay()” functions aren’t working and how I can fix it?
Obviously there is nothing wrong with the library because these functions work just fine in the demo program that comes preprogrammed on the controller.
I tried this in “debug” mode and “release” mode with no change.
I included a PDF with snapshots showing how I setup up the project in Atmel Studio 7. I also included the output from the “Buttons” code and the makefiles (there are two: one for the Arduino library, which I appended with “(ArduinoCore)”, and one for the actual program).
Makefile (6.2 KB)
Makefile (ArduinoCore) (8.5 KB)
output.txt (35.7 KB)
setup.pdf (955.9 KB)
