Good evening. We’re a university robotics team. We’re competing in a line following competition with arduino uno. Below is the robot we’ve created. We’re using a QTR sensor, but we’re experiencing some problems. The robot was functioning normally, following the line in line following. Through the calibrate that was done we got results from the serial monitor but there everything seems to be fine. As of yesterday it does not respond to the line. Below is the code we’re using. Could you help me identify the problem?
#include <QTRSensors.h>
QTRSensors qtr;
const uint8_t SensorCount = 8;
uint16_t sensorValues[SensorCount];
float Kp = 0.08;
float Ki = 0.01;
float Kd = 0.03;
float kdPrev=Kd;
float kpPrev=Kp;
//int button_pin = 12;
uint8_t maxSpeed = 255;
uint8_t preSpeed = maxSpeed;
const uint8_t minSpeed = 0;
int ENA = 5; // The pins that control the speed and direction of motors
int IN1 = 8;
int IN2 = 9;
int IN3 = 7;
int IN4 = 6;
int ENB = 10;
float eprev = 0;
unsigned long prevT;
float eintegral = 0;
bool robotMoving = false; // Flag to indicate if the robot should be moving
void setup() {
Serial.begin(9600);
delay(500);
pinMode(ENA,OUTPUT);
pinMode(IN1,OUTPUT);
pinMode(IN2,OUTPUT);
pinMode(ENB,OUTPUT);
pinMode(IN3,OUTPUT);
pinMode(IN4,OUTPUT);
pinMode(19,INPUT);
pinMode(18,INPUT);
pinMode(17,INPUT);
pinMode(16,INPUT);
pinMode(15,INPUT);
pinMode(14,INPUT);
pinMode(3 ,INPUT);
pinMode(4 ,INPUT);
// Initialize sensors
qtr.setTypeRC();
qtr.setSensorPins((const uint8_t[]){19, 18,17, 16, 15, 14, 3,4}, SensorCount);
//14, 15, 16, 17, 18, 19, 20, 21
// pinMode(button_pin, INPUT_PULLUP); // Use internal pull-up resistor
pinMode(LED_BUILTIN, OUTPUT);
calibration();
Forward(0, 0);
delay(500);
prevT = millis(); // Initialize prevT here
void loop() {
setSpeed(eprev, prevT, eintegral);
void calibration() {
digitalWrite(LED_BUILTIN, HIGH);
for (uint16_t i = 0; i < 400; i++) {
qtr.calibrate();
delay(20); // Add a small delay to allow calibration to proceed smoothly
Serial.println("wait");
digitalWrite(LED_BUILTIN, LOW);
void setSpeed(float& eprev, unsigned long& prevT, float& eintegral) {
// Time difference
unsigned long currT = millis();
float deltaT = ((float)(currT - prevT)) / 1000.0;
uint16_t position = qtr.readLineBlack(sensorValues); // Read the current position
// Error
int e = 3500- position; // 3500 is the ideal position (the center)
// Serial.println(position);
// Derivative
float dedt = (e - eprev)/ deltaT;
//float dedt = (e - eprev);
// Integral with windup guarding
eintegral += e * deltaT;
eintegral = constrain(eintegral, -1000.0, 1000.0); // Limit the integral term to prevent windup
if(position == 7000 || position == 0){float kdPrev=Kd; float kpPrev=Kp; int preSpeed = maxSpeed; maxSpeed = 150; Kp=0.08; Kd=0.03
// Control signal
float u = Kp * e + Kd * dedt + Ki * eintegral;
int rightSpeed = maxSpeed + u;
int leftSpeed = maxSpeed - u-40;
if(position == 7000 || position == 0){Kd=kdPrev; Kp=kpPrev; maxSpeed=preSpeed;}
// Constrain the motor speeds
rightSpeed = constrain(rightSpeed, minSpeed, maxSpeed);
leftSpeed = constrain(leftSpeed, minSpeed, maxSpeed);
//if(abs(e-eprev)<3000){
Forward(leftSpeed, rightSpeed); // Use the Forward function to set motor speeds
//Serial.print(leftSpeed);
//Serial.print(" ");
//Serial.print(rightSpeed);
eprev = e;
prevT = currT;}
void Forward(int speedA, int speedB) {
analogWrite(ENA, speedB);
digitalWrite(IN2, LOW);
digitalWrite(IN1, HIGH);
analogWrite(ENB, speedA);
digitalWrite(IN4, HIGH);
digitalWrite(IN3, LOW);}
