I apologize in advance if the answer is somewhere in the forum, I did a search for play function and didn’t find any help.
I am trying to learn the libraries you guys provide (which are a great help for beginners like me, thank you so much) - I am reading and trying to run the examples described in your library document. I have a Baby Orangutan that I program using the Arduino IDE and your ISP programmer. I connected a buzzer on PB2/pin 10 and I know it works because I was able to run the sample code using playNote().
Since this was successful, I decided to move along to the next example. I removed all the code having to do with LCD and button since my board doesn’t have them and I uploaded the program to the board. All I get is a continuous beep, no notes, no changes, no interruptions, no stopping. I tried using both the notes string in PROGMEM and in RAM, I tried both play and playFromProgramSpace but none works right, like I said I only get one long beep.
I thought at some point that maybe play and playFromProgSpace don’t work on the Baby board but the lib docs say they should work (provided I have a buzzer, of course).
In one case the code looks like:
#include <OrangutanBuzzer.h>
OrangutanBuzzer buzzer;
#include <avr/pgmspace.h>
const char fugue[] PROGMEM = "! O5 L16 agafaea dac+adaea ......................";
void setup() {}
void loop()
buzzer.playFromProgramSpace(fugue);
the other one I tried was:
void setup() {}
void loop()
buzzer.play("! V8 cdefgab>cbagfedc");
Is there anything I’m doing wrong? Maybe I missed something. I appreciate any help I can get. Thank you in advance!
