I’m relatively new to programming and am having trouble getting the ssc-tester to work properly.
I followed the instructions here pololu.com/projects/prj0003/
But when I run the program ($wish ssc-tester.tcl) it tells me there is an error in the startup script.
The exact message is: not connected while executing “connect” (file “ssc-tester.tcl” line 6).
The person who put up that example is not available, and I don’t really know anything about it, but another customer has found the following problems with the example:
The Tcl/Tk section for Cygwin is “Libs”.
You must also ensure that X11 is selected otherwise you will not get the X11/Xlib.h file installed which is required by tk.h.
