Npm install pololu-maestro has multiple errors, any ideas?
I have tried other packages and nothing is working for me, i am on windows 10 using 6 servo maestro.
Also interested in using on pi.
PS F:\A_Websites\Phidgettest> npm install pololu-maestro
> serialport@1.7.3 install F:\A_Websites\Phidgettest\node_modules\pololu-maestro\node_modules\serialport
> node-pre-gyp install --fallback-to-build
node-pre-gyp info it worked if it ends with ok
node-pre-gyp verb cli [
node-pre-gyp verb cli 'C:\\Program Files\\nodejs\\node.exe',
node-pre-gyp verb cli 'F:\\A_Websites\\Phidgettest\\node_modules\\pololu-maestro\\node_modules\\serialport\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp',
node-pre-gyp verb cli 'install',
node-pre-gyp verb cli '--fallback-to-build'
node-pre-gyp verb cli ]
node-pre-gyp info using node-pre-gyp@0.6.7
node-pre-gyp info using node@14.17.0 | win32 | x64
node-pre-gyp verb command install []
node-pre-gyp info check checked for "F:\A_Websites\Phidgettest\node_modules\pololu-maestro\node_modules\serialport\build\serialport\v1.7.3\Release\node-v83-win32-x64\serialport.node" (not found)
node-pre-gyp http GET https://node-serialport.s3.amazonaws.com/serialport/v1.7.3/Release/node-v83-win32-x64.tar.gz
node-pre-gyp ERR! UNCAUGHT EXCEPTION
node-pre-gyp ERR! stack ReferenceError: primordials is not defined
node-pre-gyp ERR! stack at evalmachine.<anonymous>:45:5
node-pre-gyp ERR! stack at Object.<anonymous> (F:\A_Websites\Phidgettest\node_modules\pololu-maestro\node_modules\serialport\node_modules\node-pre-gyp\node_modules\tar\node_modules\fstream\node_modules\graceful-fs\fs.js:11:1)
node-pre-gyp ERR! stack at Module._compile (internal/modules/cjs/loader.js:1068:30)
node-pre-gyp ERR! stack at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
node-pre-gyp ERR! stack at Module.load (internal/modules/cjs/loader.js:933:32)
node-pre-gyp ERR! stack at Function.Module._load (internal/modules/cjs/loader.js:774:14)
node-pre-gyp ERR! stack at Module.require (internal/modules/cjs/loader.js:957:19)
node-pre-gyp ERR! stack at require (internal/modules/cjs/helpers.js:88:18)
node-pre-gyp ERR! stack at Object.<anonymous> (F:\A_Websites\Phidgettest\node_modules\pololu-maestro\node_modules\serialport\node_modules\node-pre-gyp\node_modules\tar\node_modules\fstream\node_modules\graceful-fs\graceful-fs.js:3:27)
node-pre-gyp ERR! System Windows_NT 10.0.19042
node-pre-gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "F:\\A_Websites\\Phidgettest\\node_modules\\pololu-maestro\\node_modules\\serialport\\node_modules\\node-pre-gyp\\bin\\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd F:\A_Websites\Phidgettest\node_modules\pololu-maestro\node_modules\serialport
node-pre-gyp ERR! node -v v14.17.0
node-pre-gyp ERR! node-pre-gyp -v v0.6.7
node-pre-gyp ERR! This is a bug in `node-pre-gyp`.
node-pre-gyp ERR! Try to update node-pre-gyp and file an issue if it does not help:
node-pre-gyp ERR! <https://github.com/mapbox/node-pre-gyp/issues>
npm WARN phidgettest@1.0.0 No description
npm WARN phidgettest@1.0.0 No repository field.
npm ERR! code ELIFECYCLE
npm ERR! errno 7
npm ERR! serialport@1.7.3 install: `node-pre-gyp install --fallback-to-build`
npm ERR! Exit status 7
npm ERR!
npm ERR! Failed at the serialport@1.7.3 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\bruce\AppData\Roaming\npm-cache\_logs\2021-07-20T21_33_55_620Z-debug.log
