I have a small project I’m working on for my house. I have two wixels right now setup as transmitter and receiver. The TX module has a thermistor and some fancy math on it to send it to the receiver. I plan on adding more functionality in the future but I thought I’d start small for now. I also have the TX module dump its data to the COM port just for display purposes at this point. The issue is, the data that’s being output from the TX modules printf() statements are different from the RX modules. I’ve tried different formats %u %d %ld, etc and various integer types, nothing seems to work. Any help would be appreciated. I’m hoping its something I’m just overlooking.
-Dan
–Code for RX module
uint8 XDATA * rxData;
// Check if there is a radio packet to report and space in the
// USB TX buffers to report it.
if ((rxData = radioQueueRxCurrentPacket()) && usbComTxAvailable() >= 64)
printf("%u\r\n",rxData[1]);
printf("%f\r\n",rxData[2]);
printf("%u\r\n",rxData[3]);
printf("\r\n\r\n");
radioQueueRxDoneWithPacket();
–Code for TX Module
int32 CODE param_input_mode = 0;
int32 CODE param_send_delay = 2000;
int32 lastTx;
uint16 cTime;
uint16 rawADC;
float Temp;
int32 lastTx;
uint16 cTime;
uint16 rawADC;
float Temp;
void grabTemp()
// Assuming a 10k Thermistor. Calculation is actually: Resistance = (4096/ADC)
//Resistance = ((20470000/RawADC) - 10000);
/* Utilizes the Steinhart-Hart Thermistor Equation: */
/* Temperature in Kelvin = 1 / {A + B[ln(R)] + C[ln(R)]^3} */
/* where A = 0.001129148, B = 0.000234125 and C = 8.76741E-08 */
rawADC = adcRead(0); //Grab ADC Reading
Temp = logf(((20470000/rawADC) - 10000));
//Temp = 1 / (0.003354016 + (0.000256985 * Temp) + (0.000002620131 * Temp * Temp * Temp));
Temp = 1 / (0.001129148 + (0.000234125 * Temp) + (0.0000000876741 * Temp * Temp * Temp));
Temp = Temp - 273.15; // Convert Kelvin to Celsius
Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert to Fahrenheit
cTime = getMs();
if ((getMs() - lastTx) >= param_send_delay)
lastTx = getMs();
printf("RawADC = %u\r\n",rawADC);
printf("Temperature = %f\r\n",Temp);
printf("CTime = %d\r\n",cTime/1000);
printf("\r\n\r\n");
void txData()
static uint16 lastTx = 0;
uint8 XDATA * packet;
if ((uint16)(getMs() - lastTx) >= param_send_delay && (packet = radioQueueTxCurrentPacket()))
lastTx = getMs();
//Length
packet[0] = 2; // must not exceed RADIO_QUEUE_PAYLOAD_SIZE
//Data
packet[1] = rawADC;
packet[2] = Temp;
packet[3] = cTime;
//Send
radioQueueTxSendPacket();
