I have LiPo battery and I am afraid that it sometime will be discharged.
Is it possible to show the prevention of the battery discharge, using battery voltage monitor in SV328? Anybody did that?
It is better to use a separate protection circuit, which are small and cheap. Here is one example: batteryjunction.com/prcimopcbfor.html
Check www.all-battery.com for others.
[quote=“Jim Remington”]It is better to use a separate protection circuit, which are small and cheap. Here is one example: batteryjunction.com/prcimopcbfor.html
Check all-battery.com for others.[/quote]
Thanks, that’s a good idea! But first I will try to write a code, to check battery input voltage.
It is always a good idea to know the battery voltage! However, if you depend on the mpu to check for low voltage and it malfunctions or fails to act due to a program error, your battery will be destroyed. All-battery’s least expensive protection PCB is only $1.99. LiPo battery PCBs protect from overcharging and overcurrent, too. See all-battery.com/protectivepc … packs.aspx
