I have to do a presentation in my university about IR sensor and accurate reading. I have red few articles in which I did not got good sense, few friends of students poi tout about pololu but I could not
Can you please help me about some article in this website to read me and follow
Thanks in advanced
Pasindu
Hi Pasindu,
That’s a big topic. Are you interested in IR sensors used for obstacle detection, or IR communication or the effects that the environment has on accurate distance measurement, or …?
You might start with the data sheets for the Vishay TSSP58038 and TSSP58P38 IR receivers. Vishay also has an application note on using a IR sensor for fast proximity sensing that you might find interesting: https://www.vishay.com/docs/82741/tssp4056sensor.pdf
That looks like a great resource. Thanks for pointing it out. I noticed that there is a section on sensor calibration that might give you some ideas about accurate distance measurment.
Hi Tom,
Step one
I need to understand above code that I pointed out in my post 3rd. How it read the sensor values, I know that the corresponding pin should be input , Do you know the library that article is point out
Actually I when trough all the articles in the pololu website related to QTR sensor and it operation. All the hardware related explain is very clear for me as well as articles are explaining very well . Thanks to pololu
The hard part is to understand cording part that actual behavior in side the hardware ( in my case Microcontroller ) That what I have to present each every code that relation ship with hardware
So I will Start hare
in the QTRSensors.h file
#pragma once
#include <stdint.h>
#pragma once
this code is very clear it is preprocessor directives in c
header declare #include <stdint.h>
enum class QTRReadMode : uint8_t {
/// Each reading is made without turning on the infrared (IR) emitters. The
/// reading represents ambient light levels near the sensor.
Off,
/// Each reading is made with the emitters on. The reading is a measure of
/// reflectance.
On,
/// For each sensor, a reading is made in both the on and off states. The
/// value returned is **on + max − off**, where **on** and **off** are
/// the reading with the emitters on and off, respectively, and **max** is
/// the maximum possible sensor reading. This mode can reduce the amount of
/// interference from uneven ambient lighting.
OnAndOff,
/// The odd-numbered sensors are read with the odd-numbered emitters on, then
/// the even-numbered sensors are read with the even-numbered emitters on.
/// This mode can reduce interference between adjacent sensors, especially on
/// QTRX sensor boards. It is only usable with second-generation QTR and QTRX
/// sensor arrays that have two emitter control pins.
OddEven,
/// The odd and even sensors are read separately with the respective emitters
/// on, then all sensors are read with emitters off and **on + max −
/// off** is returned. (In other words, this mode combines OddEven and
/// OnAndOff.)
OddEvenAndOff,
/// Calling read() with this mode prevents it from automatically controlling
/// the emitters: they are left in their existing states, which allows manual
/// control of the emitters for testing and advanced use. Calibrating and
/// obtaining calibrated readings are not supported with this mode.
Manual
As per what I can understood the class QTRReadMode is for two type of sensor which is QTR old and QTRX. So I not need complicate my presentation much and I only have old pololu red color QTRC type sensor. Hence can I remove the "OddEven"and OddEvenAndOff from the code otherwise I have to explain them during the presentation
The QTR sensor has an IR emitter and an IR detector. QTRReadMode controls whether or not the emitter is on during the readings. The purpose of this is described in the comments of the code you posted. With the emitter off, you can get readings using the ambient light levels near the sensor. With the emitter on, it measures the reflectance (this is the most common measurement method). OnAndOff takes a reading with and without the emitter and considers both to help account for uneven ambient lighting. As you mentioned OddEven and OddEvenAndOff do not apply to all of the QTR reflectance sensors like the older QTR-8A and QTR-8RC arrays.
Yes Brandon , Now I am very clear usage of constant enum class of QTRReadMode but I don’t know where it applies in the code , I mean enum constant. Can you please help me where this enum constants are using in the code
It is not entirely clear to me what you are asking, but the calibration and reading methods all use the QTRReadMode setting to decide how to take the readings. You can find the code for that in QTRSensors.cpp. They also take an optional argument to set the QTRReadMode for that particular reading.
As far as the max timeout value, if no timeout value is otherwise specified, the library will use 2500. This can be found on line 67 of QTRSensors.h.
If that does not answer your questions, could you try rephrasing them to be more specific?
If you’re looking for the code responsible for taking the measurements using the sensor, you can refer to the readPrivate() function, which starts on line 557. For the RC type specifically, the code is between line 563 and 613.
Earlier in the function, the sensor pins were driven high and the sensor values were all set to the maximum timeout value.The purpose of that IF statement is to check if the voltage has decayed enough for them to read low yet. If it has, and the time has not previously been recorded yet, it updates the sensor value to the current value on the timer.
The first portion of that IF statement ,(digitalRead(_sensorPins[i]) == LOW), is checking if the sensor pin is reading low yet.
The second portion of the IF statement, (time < sensorValues[i]), is checking if this is the first time we’ve recorded the pin being low. If it is, the current time will be less than the existing value of sensorValues[i] (since it was initialized to the max value possible), and we will save the current time. However, if the time was already previously recorded, the current time will be greater than what was already saved, so we won’t update it again.
As described on our QTR-RC product pages, the typical sequence for reading a sensor is:
Turn on IR LEDs (optional).
Set the I/O line to an output and drive it high.
Allow at least 10 ÎĽs for the sensor output to rise.
Make the I/O line an input (high impedance).
Measure the time for the voltage to decay by waiting for the I/O line to go low.
Turn off IR LEDs (optional).
The time variable in that code is measuring how long it takes for the voltage to decay (i.e. step 5), and that time measurement is what the library outputs as the sensor reading.
If you still haven’t looked it over, I recommend reading through the application note I linked to in one of my previous posts here.
