hello all!
I should begin by mentioning I am a complete newbie when it comes to electronics. Extremely ignorant, so please pardon my stupid questions - I’m trying to learn as much as I can!
The plan was to figure out how to make my own electronic remote follow focus system for filmmaking with DSLR video cameras. After a few days of reading, I decided to purchase the Arduino Uno, Easydriver v4.4, Pololu 12v power supply, and the Pololu 4v 1200mA Stepper Motor https://www.pololu.com/catalog/product/1200.
I wired it up exactly like a schematic I found online http://danthompsonsblog.blogspot.com/2010/05/easydriver-42-tutorial.html but ran into trouble figuring out how to power my specific stepper motor. I assumed a 12v power supply would be sufficient to power the 4v motor but things got a little confusing understanding the mA ratings per coil, etc. Also, the color coded wiring was different than the example in the tutorial. The Pololu stepper motor page shows which wires to isolate for bipolar drivers but I’m lost as to which pairs connect to the A, B coil outputs on the easydriver. I fired up the aurduino and easydriver, code from the tutorial ran fine, but motor didn’t move at all. I tried switching coil pairs but no difference… only small noises coming from the motor.
I’m sure I’m missing something obvious here… if someone might be able to help out a newbie I’d really appreciate it!
// Stepper Motor skecth for use with the EasyDriver v4.2 //
// Dan Thompson 2010
// Use this code at your own risk.
// For all the product details visit http://www.schmalzhaus.com/EasyDriver/
// For the full tutorial visit http://danthompsonsblog.blogspot.com/
////// ED_v4 Step Mode Chart //////
// MS1 MS2 Resolution //
// L L Full step (2 phase) //
// H L Half step //
// L H Quarter step //
// H H Eighth step //
int DIR = 3; // PIN 3 = DIR
int STEP = 2; // PIN 2 = STEP
int MS1 = 13; // PIN 13 = MS
int MS2 = 9; // PIN 9 = MS2
int SLEEP = 12; // PIN 12 = SLP
void setup() {
Serial.begin(9600); // open the serial connection at 9600bps
pinMode(DIR, OUTPUT); // set pin 3 to output
pinMode(STEP, OUTPUT); // set pin 2 to output
pinMode(MS1, OUTPUT); // set pin 13 to output
pinMode(MS2, OUTPUT); // set pin 9 to output
pinMode(SLEEP, OUTPUT); // set pin 12 to output
void loop()
int modeType = 1; // This number increases by multiple of 2 each through the while loop..
// ..to identify our step mode type.
while (modeType<=8){ // loops the following block of code 4 times before repeating .
digitalWrite(DIR, LOW); // Set the direction change LOW to HIGH to go in opposite direction
digitalWrite(MS1, MS1_MODE(modeType)); // Set state of MS1 based on the returned value from the MS1_MODE() switch statement.
digitalWrite(MS2, MS2_MODE(modeType)); // Set state of MS2 based on the returned value from the MS2_MODE() switch statement.
digitalWrite(SLEEP, HIGH); // Set the Sleep mode to AWAKE.
int i = 0; // Set the counter variable.
while(i<(modeType*200)) // Iterate for 200, then 400, then 800, then 1600 steps.
// Then reset to 200 and start again.
digitalWrite(STEP, LOW); // This LOW to HIGH change is what creates the..
digitalWrite(STEP, HIGH); // .."Rising Edge" so the easydriver knows to when to step.
delayMicroseconds(1600/modeType); // This delay time determines the speed of the stepper motor.
// Delay shortens from 1600 to 800 to 400 to 200 then resets
i++;
modeType = modeType * 2; // Multiply the current modeType value by 2 and make the result the new value for modeType.
// This will make the modeType variable count 1,2,4,8 each time we pass though the while loop.
delay(500);
digitalWrite(SLEEP, LOW); // switch off the power to stepper
Serial.print("SLEEPING..");
delay(1000);
Serial.print("z");
delay(1000);
Serial.print("z");
delay(1000);
Serial.print("z");
delay(1000);
Serial.println("");
Serial.println("AWAKE!!!"); // Switch on the power to stepper
delay(1000);
int MS1_MODE(int MS1_StepMode){ // A function that returns a High or Low state number for MS1 pin
switch(MS1_StepMode){ // Switch statement for changing the MS1 pin state
// Different input states allowed are 1,2,4 or 8
case 1:
MS1_StepMode = 0;
Serial.println("Step Mode is Full...");
break;
case 2:
MS1_StepMode = 1;
Serial.println("Step Mode is Half...");
break;
case 4:
MS1_StepMode = 0;
Serial.println("Step Mode is Quarter...");
break;
case 8:
MS1_StepMode = 1;
Serial.println("Step Mode is Eighth...");
break;
return MS1_StepMode;
int MS2_MODE(int MS2_StepMode){ // A function that returns a High or Low state number for MS2 pin
switch(MS2_StepMode){ // Switch statement for changing the MS2 pin state
case 1:
MS2_StepMode = 0;
break;
case 2:
MS2_StepMode = 0;
break;
case 4:
MS2_StepMode = 1;
break;
case 8:
MS2_StepMode = 1;
break;
return MS2_StepMode;
