HI, total newb here, figuring out things as I go. Using a Maestro 12, have 6v powering my existing servos. Now, I have use for a 12/24v servo, and want to see if I can control it from this board? I know it needs a separate power supply, and it has a 5V Signal Input. Here is the model…
Is it possible, and if so, what do I need? Thank you friends.
I do not see any reason you should not be able to control that servo using the Maestro. If you have other servos that require less than 12V, I suggest powering the 12V servo away from the Maestro, making sure to still have a common ground between the two, along with the signal wire connection.
Thanks for the reply! Would I use one of the servo regular servo outputs into the control input on the 12v servo? My main concern was that it’s a 0-5v input and I think I’m pushing 6v out. Not sure if that would affect anything. Thanks!
