I get a flicker out of the 3 led’s, but then nothing as best as I can tell.
Is there a command I can send it, that will force some type of response just so I can tell it’s working and I’m able to speak to the controller from my PC?
I’m using 4 AAA’s 6.2 volt for the controller board and a 7.2 nimh for the servo’s
I’m use 4 AAA’s in serial to make 6-6.2 volts at full charge for the logic board. when I plug int he battler the LED’s blink once, then nothing.
I connect to the board using the pololu communication tool. (I forget what it was called)
and send 1 to 6 byte commands, they look like they go but the board doesn’t respond.
Byte Sent
Byte Sent
Byte Sent
Type responses, with nothing shows received. I’m unsure if the commands are making it to the board, my guess is not.
What does the LED’s on board do during normal operation?
Is there a byte sequence that can be sent, that the board will always respond to, so I’m certain the board is receiving the commands?
The LED behavior is described on page 4 of the user’s guide (above and below the “Indicator LEDs” heading). If you’re getting all of the LEDs to flash, there’s probably something wrong with your power setup. If you connect just your logic power, and nothing else, you should see just the yellow LED turn on. Is that what you see?
