Just to clarify, are you saying the problem persists even after making that change?
It looks like there are a couple other modifications to the code aside from the address value. If you’re still having problems, could you try keeping everything except the address value in the example unmodified (or using the completely unmodified example and changing the address on you RoboClaw to match instead)? Also, are you still using the Arduino Mega 2560 as mentioned in your other thread?
