I have been using the Polulu PGM03A to successfully program boards from the Arduino IDE for several months. Today, while attempting to upload from the Arduino IDE, I got an error message that I have never seen before:
Both of the boards I have been programming are ATMega168-based. One is custom, the other is a Makerbot DC servo controller v1.0, which is similar to an Arduino Mini, and uses ATMega168. On the Makerbot DC servo controller board, I can still successfully program it from the Arduino IDE using an FTDI USB-to-serial 6 pin cable (tested with both 5v and 3.3v versions). I only have ICSP on the other board, hence my need to fix my problem. Both are clocked 16MHz and both work and program from the IDE until today.
When I first plug in the PGM03A to USB, I get steady green LED and 1Hz 50% duty cycle red LED. When I plug this into the powered Arduino boards, I get blinking amber LED with steady green LED, red off. According to the PGM03A manual, this indicates that the programmer is able to detect Vdd-high on a target device.
After an unsuccessful code upload attempt from the Arduino IDE, I get steady green, steady red, and blinking amber LED, as well as the error message quoted above. When I open the Polulu USB AVR programmer configuration utility, I get the device serial, firmware version 1.07, 200kHz, hardware v F, software v 2A, TTL A none, TTLB none, tgt Vdd 4384, 512, measurements 4832, 0, and the following :
As stated, the micros are clocked at 16MHz so the 200kHz ISP frequency is slower than 0.25x.
I get the errors quoted above when trying to program either board using the Arduino IDE → polulu PGM03a approach. I have double-checked and triple checked the COM port settings and programmer settings in the IDE. I have swapped out the micro USB cable to the Polulu PGM03A, and I have also swapped out the 6-pin ICSP ribbon cable. I don’t think it is a cable connectivity issue or an IDE settings issue, since the settings worked until today and both cables have been swapped.
Is the PGM03A burned out? any other ideas?
