PololuQTRSensor trouble
Hi All,
I am having trouble with a PololuQTRSensor (Analog version) which I just purchased.
Having wired the sensor to a SparkFun WEE, SparkFuns version of the mini Arduino, I programmed it (the Wee) with some code to quickly test the sensor using LillyPad as the poard option.
This is the test code which works fine:
int ledPin = 13;   // select the pin for the LED
int val0 = 0;       //
int val1 = 0;       //
int val2 = 0;       //
int val3 = 0;       //
int val4 = 0;       //
int val5 = 0;       //
long cnt = 0;
void setup() {
  pinMode(9, OUTPUT);  // declare the ledPin as an OUTPUT
  Serial.begin(9600);
void loop() {
  cnt++;
  digitalWrite(9, (cnt%2));   // sets 9
  val0 = analogRead(0);    //
  val1 = analogRead(1);    //
  val2 = analogRead(2);    //
  val3 = analogRead(3);    //
  val4 = analogRead(4);    //
  val5 = analogRead(5);    //
  Serial.print(val0);
  Serial.print("\t");
  Serial.print(val1);
  Serial.print("\t");
  Serial.print(val2);
  Serial.print("\t");
  Serial.print(val3);
  Serial.print("\t");
  Serial.print(val4);
  Serial.print("\t");
  Serial.print(val5);
  Serial.print("\t");
  Serial.println();
  delay(100);                  // stop the program for some time
I then tried to use the class lib supplied from Popolu and it produces all zeros for the readings. I am sure this is some thing simple… the code is as follows:
#include <PololuQTRSensors.h>
#define NUMSENSORS 6
#define SAMPLES 3
#define EMITTERPIN 9
unsigned int sensors[8];
long  cnt = 0;
unsigned int line = 0;
PololuQTRSensorsAnalog qtra((unsigned char[]) {0, 1, 2, 3, 4, 5}, NUMSENSORS, SAMPLES, EMITTERPIN);
void setup()
  Serial.begin(9600);
  Serial.println("Starting to Calibrate");
  int i;
  for (i = 0; i < 250; i++) {   // make the calibration take about 5 seconds
    qtra.calibrate(QTR_EMITTERS_OFF);
    Serial.print(".");
    delay(20);
  Serial.println();
  Serial.println("Finished calibrating");
  delay(100);
  unsigned int *pArry;
  pArry = qtra.calibratedMinimumOn;
  Serial.print("calibratedMinimumOn    ");
  for (i=0; i<NUMSENSORS; i++) {
    Serial.print("\t");
    Serial.print(pArry[0]);
  Serial.println();
  pArry = qtra.calibratedMaximumOn;
  Serial.print("calibratedMaximumOn    ");
    Serial.print("\t");
  Serial.println();
  pArry = qtra.calibratedMinimumOff;
  Serial.print("calibratedMinimumOff    ");
    Serial.print("\t");
  Serial.println();
  pArry = qtra.calibratedMaximumOff;
  Serial.print("calibratedMaximumOff    ");
    Serial.print("\t");
  Serial.println();
  delay(10000);
void loop()
  int i;
  Serial.println(cnt++);
  qtra.readCalibrated(sensors, QTR_EMITTERS_OFF);
  Serial.print("  EMITTERS_OFF  ");
    Serial.print("\t");
    Serial.print(sensors[i]);
  Serial.println();
  qtra.readCalibrated(sensors, QTR_EMITTERS_ON);
  Serial.print("  EMITTERS_ON  ");
    Serial.print("\t");
  Serial.println();
  qtra.readCalibrated(sensors, QTR_EMITTERS_ON_AND_OFF);
  Serial.print("  EMITTERS_ON_OFF  ");
    Serial.print("\t");
  Serial.println();
  Serial.print("  Cal EMITTERS_ON  ");
    Serial.print("\t");
  Serial.println();
  line = qtra.readLine(sensors);
  Serial.print("    line = ");
  Serial.print(line);
  Serial.println();
  delay(250);                  // stop the program for some time
Any ideas?
Phil
There are a few things that could be causing you to read all zeroes. The first is using calibrated read functions with improper calibration (or no calibration). I notice that in your code you are only calibrating with the emitters off, which could be the source of your problems. I suggest you either calibrate with the emitters on and off, or just with the emitters on. In general, I suggest you do everything with the emitters on as that is how the sensors work best. The benefit to taking readings with the emitters off is that you can use the information to mitigate the effects of changing ambient IR, but in most situations this is probably unnecessary. While you are running the calibration routine, make sure you sweep each sensor over the darkest black and brightest white it will encounter so it can learn what to consider full black and what to consider full white. If a sensor isn’t calibrated for both black and white, the calibrated readings you get from it will be unreliable.
Please let me know if calibrating with the emitters on helps you to get things working.
- Ben
Hi Ben,
thanks you for your prompt response.
I have tried calibrating with emitters on and off and also reading in both ways also. However, I suspect that is what I’m doing wrong is invalidly calibrating.
The calibration I’ve been doing is simply with the sensor sitting over white paper and about 1/8" away. Now that you say I should sweep it over black and white it makes sense :slight_smile:
So, correct em if I’m wrong, I should start the calibration process and during the 5 seconds its running I should show the sensor all black and then all white?
Regards
Phil
That’s correct. The point of calibrating is to tell the sensors what to consider full black and full white so they can give you readings relative the extremes they will encounter during operation. The benefit of this is that you can write code to, say, follow a black line on a white course using calibrated readings, and that same code should still work when following a black line on a gray course using calibrated readings. Note that for some applications it might be easier/more appropriate to skip the calibration phase and just use raw (uncalibrated) sensor readings.
- Ben
Hi Ben,
thank you again for your prompt response.
I have tried to get this to work several times since our last posts and I’'m still unable to have it to make sense. I’ve tried the program with multiple settings and as many ways as it appears to make sense.
Attached is the output from the Arduino console when showing the sensor black then white during the 5 second calibration:
calibratedMinimumOn        1023    1023    1023    1023    1023    1023
calibratedMaximumOn        1023    1023    1023    1023    1023    1023
calibratedMinimumOff        128    128    128    128    128    128
calibratedMaximumOff        128    128    128    128    128    128
0
  EMITTERS_OFF      0    0    0    0    0    0
  EMITTERS_ON      0    0    0    0    0    0
  EMITTERS_ON_OFF      0    0    0    0    0    0
  Cal EMITTERS_ON      0    0    0    0    0    0
    line = 0
1
    line = 0
2
    line = 0
This is the current code:
#define SAMPLES 3
long  cnt = 0;
void setup()
  Serial.begin(9600);
  int i;
    qtra.calibrate(QTR_EMITTERS_ON);
    Serial.print(".");
    delay(20);
  Serial.println();
  delay(100);
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  delay(10000);
void loop()
  int i;
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  Serial.print(line);
  Serial.println();
Hi Ben,
I’ve posted the current code.
In actual fact I’ve tried calibration and reading with just about every combination. All produce similar results.
Phil
I’ll do some tests here tomorrow to see if I can figure out what’s going on, but in the mean time, what results do you get if you just try to read the raw (uncalibrated) sensor values?
- Ben
Hi Ben,
These are the raw results:
Code:
#define SAMPLES 3
long  cnt = 0;
void setup()
  int i;
  Serial.begin(9600);
  Serial.print("  Starting  ");
  Serial.println();
  delay(3000);
void loop()
  int i;
  qtra.read(sensors, QTR_EMITTERS_ON);
    Serial.print("\t");
  Serial.println();
  qtra.read(sensors, QTR_EMITTERS_OFF);
    Serial.print("\t");
  Serial.println();
output:
76
  EMITTERS_ON  	1023	1023	1023	1023	1023	1023
  EMITTERS_OFF  	1023	1023	1023	1023	1023	1023
77
78
79
80
81
82
83
84
Hi Ben,
just for comparison, this is the none pololu class code I posted in the first post which appears to work:
code:
 * AnalogInput
 * by DojoDave <http://www.0j0.org>
 * Turns on and off a light emitting diode(LED) connected to digital
 * pin 13. The amount of time the LED will be on and off depends on
 * the value obtained by analogRead(). In the easiest case we connect
 * a potentiometer to analog pin 2.
 * http://www.arduino.cc/en/Tutorial/AnalogInput
int val0 = 0;       //
int val1 = 0;       //
int val2 = 0;       //
int val3 = 0;       //
int val4 = 0;       //
int val5 = 0;       //
long cnt = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  cnt++;
  Serial.print(val0);
  Serial.print("\t");
  Serial.print(val1);
  Serial.print("\t");
  Serial.print(val2);
  Serial.print("\t");
  Serial.print(val3);
  Serial.print("\t");
  Serial.print(val4);
  Serial.print("\t");
  Serial.print(val5);
  Serial.print("\t");
  Serial.println();
Output
39	30	27	42	267	541
73	350	541	773	912	995
28	31	27	41	266	540
76	357	547	776	913	995
28	31	27	41	266	541
68	342	535	769	910	994
25	31	27	41	266	541
73	350	541	773	911	994
34	31	27	41	266	540
66	338	532	767	908	993
33	31	27	41	266	540
72	349	541	772	911	994
32	31	27	42	266	540
67	340	535	768	909	993
31	31	27	41	266	540
Thanks for the information. I plan on doing some tests later today, so hopefully I’ll have some more information for you soon.
- Ben
Thanks Ben,
don’t hesitate to ask for additional information or tests.
Phil
Phil, when did you download your QTR sensor library? On August 26 we released a newer version that fixed a problem with the library. Can you try your program again with this newer library if you haven’t already? I’ve done some limited tests and so far everything is working ok for me. If using the new library doesn’t fix things, please let me know and I’ll conduct some more detailed tests.
- Ben
hi Ben,
Well, I probably down loaded it several weeks ago. I’ve been messing with this for quite some tome trying to get it to work, before finally posting on the forum.
Is there a current release version?
I’ll re download and see how it goes.
best
Phil
Hi Ben,
I followed the instructions for installign the new libs:
Removed the old version from arduino-0011\hardware\libraries\PololuQTRSensors and installed the new folder in the same location. The folder did not have a “.o” file. I loaded and compiled my app and during that process a “.o” was created and I assumed linked into the app.
The results are identical to those in my last posts, that is, it does not appear to work.
My code is the same as posted before and these are the header and cpp files I’m using from pololu:
  PololuQTRSensors.h - Library for using Pololu QTR reflectance
	sensors and reflectance sensor arrays: QTR-1A, QTR-8A, QTR-1RC, and
	QTR-8RC.  The object used will determine the type of the sensor (either
	QTR-xA or QTR-xRC).  Then simply specify in the constructor which
	Arduino I/O pins are connected to a QTR sensor, and the read() method
	will obtain reflectance measurements for those sensors.  Smaller sensor
	values correspond to higher reflectance (e.g. white) while larger
	sensor values correspond to lower reflectance (e.g. black or a void).
	* PololuQTRSensorsRC should be used for QTR-1RC and QTR-8RC sensors.
	* PololuQTRSensorsAnalog should be used for QTR-1A and QTR-8A sensors.
 * Written by Ben Schmidel et al., May 28, 2008.
 * Copyright (c) 2008 Pololu Corporation. For more information, see
 *   https://www.pololu.com
 *   https://forum.pololu.com
 *   https://www.pololu.com/docs/0J18/9
 * You may freely modify and share this code, as long as you keep this
 * notice intact (including the two links above).  Licensed under the
 * Creative Commons BY-SA 3.0 license:
 *   http://creativecommons.org/licenses/by-sa/3.0/
 * Disclaimer: To the extent permitted by law, Pololu provides this work
 * without any warranty.  It might be defective, in which case you agree
 * to be responsible for all resulting costs and damages.
#ifndef PololuQTRSensors_h
#define PololuQTRSensors_h
#define QTR_EMITTERS_OFF 0
#define QTR_EMITTERS_ON 1
#define QTR_EMITTERS_ON_AND_OFF 2
// This class cannot be instantiated directly (it has no constructor).
// Instead, you should instantiate one of its two derived classes (either the
// QTR-A or QTR-RC version, depending on the type of your sensor).
class PololuQTRSensors
  public:
	// Reads the sensor values into an array. There *MUST* be space
	// for as many values as there were sensors specified in the constructor.
	// Example usage:
	// unsigned int sensor_values[8];
	// sensors.read(sensor_values);
	// The values returned are a measure of the reflectance in abstract units,
	// with higher values corresponding to lower reflectance (e.g. a black
	// surface or a void).
	// If measureOffAndOn is true, measures the values with the
	// emitters on AND off and returns on - (timeout - off).  If this
	// value is less than zero, it returns zero.
	// This method will call the appropriate derived class' readPrivate(), as
	// determined by the _type data member.  Making this method virtual
	// leads to compiler warnings, which is why this alternate approach was
	// taken.
	void read(unsigned int *sensor_values, unsigned char readMode = QTR_EMITTERS_ON);
	// Turn the IR LEDs off and on.  This is mainly for use by the
	// read method, and calling these functions before or
	// after the reading the sensors will have no effect on the
	// readings, but you may wish to use these for testing purposes.
	void emittersOff();
	void emittersOn();
	// Reads the sensors for calibration.  The sensor values are
	// not returned; instead, the maximum and minimum values found
	// over time are stored internally and used for the
	// readCalibrated() method.
	void calibrate(unsigned char readMode = QTR_EMITTERS_ON);
	// Returns values calibrated to a value between 0 and 1000, where
	// 0 corresponds to the minimum value read by calibrate() and 1000
	// corresponds to the maximum value.  Calibration values are
	// stored separately for each sensor, so that differences in the
	// sensors are accounted for automatically.
	void readCalibrated(unsigned int *sensor_values, unsigned char readMode = QTR_EMITTERS_ON);
	// Operates the same as read calibrated, but also returns an
	// estimated position of the robot with respect to a line. The
	// estimate is made using a weighted average of the sensor indices
	// multiplied by 1000, so that a return value of 0 indicates that
	// the line is directly below sensor 0, a return value of 1000
	// indicates that the line is directly below sensor 1, 2000
	// indicates that it's below sensor 2000, etc.  Intermediate
	// values indicate that the line is between two sensors.  The
	// formula is:
	//    0*value0 + 1000*value1 + 2000*value2 + ...
	//         value0  +  value1  +  value2 + ...
	// By default, this function assumes a dark line (high values)
	// surrounded by white (low values).  If your line is light on
	// black, set the optional second argument white_line to true.  In
	// this case, each sensor value will be replaced by (1000-value)
	// before the averaging.
	int readLine(unsigned int *sensor_values, unsigned char readMode = QTR_EMITTERS_ON, unsigned char white_line = 0);
	// Calibrated minumum and maximum values. These start at 1000 and
	// 0, respectively, so that the very first sensor reading will
	// update both of them.
	// The pointers are unallocated until calibrate() is called, and
	// then allocated to exactly the size required.  Depending on the
	// readMode argument to calibrate, only the On or Off values may
	// be allocated, as required.
	// These variables are made public so that you can use them for
	// your own calculations and do things like saving the values to
	// EEPROM, performing sanity checking, etc.
	unsigned int *calibratedMinimumOn;
	unsigned int *calibratedMaximumOn;
	unsigned int *calibratedMinimumOff;
	unsigned int *calibratedMaximumOff;
	~PololuQTRSensors();
  protected:
	PololuQTRSensors()
	void init(unsigned char numSensors, unsigned char emitterPin,
		unsigned char type);
	unsigned char _numSensors;
	unsigned char _emitterBitmask;
	// pointer to emitter PORT register
	volatile unsigned char* _emitterPORT;	// needs to be volatile
	// pointer to emitter DDR register
	volatile unsigned char* _emitterDDR;		// needs to be volatile
	unsigned int _maxValue; // the maximum value returned by this function
  private:
	unsigned char _type;	// the type of the derived class (QTR_RC
							// or QTR_A)
	// Handles the actual calibration. calibratedMinimum and
	// calibratedMaximum are pointers to the requested calibration
	// arrays, which will be allocated if necessary.
	void calibrateOnOrOff(unsigned int **calibratedMinimum,
						  unsigned int **calibratedMaximum,
						  unsigned char readMode);
// Object to be used for QTR-1RC and QTR-8RC sensors
class PololuQTRSensorsRC : public PololuQTRSensors
	// allows the base PololuQTRSensors class to access this class'
	// readPrivate()
	friend class PololuQTRSensors;
  public:
	// if this constructor is used, the user must call init() before using
	// the methods in this class
	PololuQTRSensorsRC() { }
	// this constructor just calls init()
	PololuQTRSensorsRC(unsigned char* pins, unsigned char numSensors,
		  unsigned int timeout = 4000, unsigned char emitterPin = 255);
	// the array 'pins' contains the Arduino pin assignment for each
	// sensor.  For example, if pins is {3, 6, 15}, sensor 1 is on
	// Arduino digital pin 3, sensor 2 is on Arduino digital pin 6,
	// and sensor 3 is on Arduino analog input 1 (digital pin 15).
	// Note that Arduino digital pins 0 - 7 correpsond to port D
	// pins PD0 - PD7, respectively.  Arduino digital pins 8 - 13
	// correspond to port B pins PB0 - PB5.  Arduino analog inputs
	// 0 - 5 are referred to as digital pins 14 - 19 (these are the
	// enumerations you should use for this library) and correspond
	// to port C pins PC0 - PC5.
	// 'numSensors' specifies the length of the 'pins' array (i.e. the
	// number of QTR-RC sensors you are using).  numSensors must be
	// no greater than 8.
	// 'timeout' specifies the length of time in timer2 counts beyond
	// which you consider the sensor reading completely black.  That is to say,
	// if the pulse length for a pin exceeds 'timeout', pulse timing will stop
	// and the reading for that pin will be considered full black.
	// It is recommended that you set timeout to be between 1000 and
	// 3000 us, depending on things like the height of your sensors and
	// ambient lighting.  Using timeout allows you to shorten the
	// duration of a sensor-reading cycle while still maintaining
	// useful analog measurements of reflectance.  On a 16 MHz microcontroller,
	// you can convert timer2 counts to microseconds by dividing by 2
	// (i.e. 2000 us = 4000 timer2 counts = 'timeout' of 4000).  On a 20 MHz
	// microcontroller, you can convert timer2 counts to microseconds by
	// dividing by 2.5 or multiplying by 0.4
	// (i.e. 2000 us = 5000 timer2 counts = 'timeout' of 5000).
	// emitterPin is the Arduino digital pin that controls whether the IR LEDs
	// are on or off.  This pin is optional and only exists on the 8A and 8RC
	// QTR sensor arrays.  If a valid pin is specified,
	// the emitters will only be turned on during a reading.  If an invalid
	// pin is specified (e.g. 255), the IR emitters will always be on.
	void init(unsigned char* pins, unsigned char numSensors,
  private:
	// Example usage:
	// The values returned are a measure of the reflectance in timer2 counts,
	// surface or a void).  Timer2 will be running at the MCU clock / 8, which
	// means 2 MHz for a 16 MHz MCU and 2.5 MHz for a 20 MHz MCU.
	void readPrivate(unsigned int *sensor_values);
  private:
	unsigned char _bitmask[8];
	// pointer to PIN registers
	volatile unsigned char* _register[8];	// needs to be volatile
	unsigned char _portBMask;
	unsigned char _portCMask;
	unsigned char _portDMask;
// Object to be used for QTR-1A and QTR-8A sensors
class PololuQTRSensorsAnalog : public PololuQTRSensors
	// readPrivate()
  public:
	PololuQTRSensorsAnalog() { }
	PololuQTRSensorsAnalog(unsigned char* analogPins,
		unsigned char numSensors, unsigned char numSamplesPerSensor = 4,
	// the array 'pins' contains the Arduino analog pin assignment for each
	// sensor.  For example, if pins is {0, 1, 7}, sensor 1 is on
	// Arduino analog input 0, sensor 2 is on Arduino analog input 1,
	// and sensor 3 is on Arduino analog input 7.  The ATmega168 has 8
	// total analog input channels (0 - 7) that correspond to port C
	// pins PC0 - PC7.
	// 'numSensors' specifies the length of the 'analogPins' array (i.e. the
	// number of QTR-A sensors you are using).  numSensors must be
	// 'numSamplesPerSensor' indicates the number of 10-bit analog samples
	// to average per channel (i.e. per sensor) for each reading.  The total
	// number of analog-to-digital conversions performed will be equal to
	// numSensors*numSamplesPerSensor.  Note that the amount of time it takes
	// to perform a single analog-to-digital conversion is approximately:
	// 128 * 13 / F_CPU = 1664 / F_CPU
	// If F_CPU is 16 MHz, as on most Arduinos, this becomes:
	// 1664 / 16 MHz = 104 us
	// So if numSamplesPerSensor is 4 and numSensors is, say, 6, it will take
	// 4 * 6 * 104 us = 2.5 ms to perform a full readLine() if F_CPU is 16 MHz.
	// Increasing this parameter increases noise suppression at the cost of
	// sample rate.  Recommended value: 4.
	// QTR sensor arrays.  If a valid pin is specified, the emitters will only
	// be turned on during a reading.  If an invalid pin is specified
	// (e.g. 255), the IR emitters will always be on.
	void init(unsigned char* analogPins, unsigned char numSensors,
		unsigned char numSamplesPerSensor = 4, unsigned char emitterPin = 255);
  private:
	// Example usage:
	// The values returned are a measure of the reflectance in terms of a
	// 10-bit ADC average with higher values corresponding to lower
	// reflectance (e.g. a black surface or a void).
  private:
	unsigned char _analogPins[8];
	unsigned char _numSamplesPerSensor;
#endif
// Local Variables: **
// mode: C++ **
// c-basic-offset: 4 **
// tab-width: 4 **
// indent-tabs-mode: t **
// end: **
  PololuQTRSensors.cpp - Library for using Pololu QTR reflectance
#ifndef F_CPU
#define F_CPU 20000000UL
#endif
#include <avr/io.h>
#include <stdlib.h>
#include "PololuQTRSensors.h"
#define QTR_RC		0
#define QTR_A		1
#ifdef LIB_POLOLU
#include "../OrangutanTime/OrangutanTime.h"		// provides access to delay routines
// two options for our sensors
// one pointer to the type in use
static PololuQTRSensors *qtr;
extern "C" void qtr_emitters_on()
	qtr->emittersOn();
extern "C" void qtr_emitters_off()
	qtr->emittersOff();
extern "C" char qtr_rc_init(unsigned char* pins, unsigned char numSensors,
			    unsigned int timeout, unsigned char emitterPin)
	PololuQTRSensorsRC *qtr_rc = (PololuQTRSensorsRC *)malloc(sizeof(PololuQTRSensorsRC));
	if(!qtr_rc)
		return 0; // out of memory
	qtr_rc->init(pins, numSensors, timeout, emitterPin);
	qtr = qtr_rc;
	return 1;
extern "C" char qtr_analog_init(unsigned char* analogPins, unsigned char numSensors,
		unsigned char numSamplesPerSensor, unsigned char emitterPin)
	PololuQTRSensorsAnalog *qtr_analog = (PololuQTRSensorsAnalog *)malloc(sizeof(PololuQTRSensorsAnalog));
	if(!qtr_analog)
	qtr_analog->init(analogPins, numSensors, numSamplesPerSensor, emitterPin);
	qtr = qtr_analog;
	return 1;
extern "C" void qtr_read(unsigned int *sensor_values, unsigned char readMode) {
	qtr->read(sensor_values,readMode);
extern "C" void qtr_calibrate(unsigned char readMode)
	qtr->calibrate(readMode);
extern "C" void qtr_read_calibrated(unsigned int *sensor_values, unsigned char readMode)
	qtr->readCalibrated(sensor_values, readMode);
extern "C" int qtr_read_line(unsigned int *sensor_values, unsigned char readMode)
	return qtr->readLine(sensor_values, readMode, false);
extern "C" int qtr_read_line_white(unsigned int *sensor_values, unsigned char readMode)
	return qtr->readLine(sensor_values, readMode, true);
#else
#include "wiring.h"		// provides access to delay() and delayMicroseconds()
#endif
// Base class data member initialization (called by derived class init())
void PololuQTRSensors::init(unsigned char numSensors,
  unsigned char emitterPin, unsigned char type)
	calibratedMinimumOn=0;
	calibratedMaximumOn=0;
	calibratedMinimumOff=0;
	calibratedMaximumOff=0;
	if (numSensors > 8)
		_numSensors = 8;
	else
		_numSensors = numSensors;
	_type = type;
	if (emitterPin < 8)				// port D
		_emitterBitmask = 1 << emitterPin;
		_emitterPORT = &PORTD;
		_emitterDDR = &DDRD;
	else if (emitterPin < 14)		// port B
		_emitterBitmask = 1 << (emitterPin - 8);
		_emitterPORT = &PORTB;
		_emitterDDR = &DDRB;
	else if (emitterPin < 20)		// port C
		_emitterBitmask = 1 << (emitterPin - 14);
		_emitterPORT = &PORTC;
		_emitterDDR = &DDRC;
	else
		_emitterDDR = 0;
		_emitterPORT = 0;
// Example usage:
void PololuQTRSensors::read(unsigned int *sensor_values, unsigned char readMode)
	unsigned int off_values[8];
	unsigned char i;
	if(readMode == QTR_EMITTERS_ON || readMode == QTR_EMITTERS_ON_AND_OFF)
		emittersOn();
	if (_type == QTR_RC)
		((PololuQTRSensorsRC*)this)->readPrivate(sensor_values);
		emittersOff();
		if(readMode == QTR_EMITTERS_ON_AND_OFF)
			((PololuQTRSensorsRC*)this)->readPrivate(off_values);
	else
		((PololuQTRSensorsAnalog*)this)->readPrivate(sensor_values);
		emittersOff();
		for(i=0;i<_numSensors;i++)
			sensor_values[i] += _maxValue - off_values[i];
void PololuQTRSensors::emittersOff()
	if (_emitterDDR == 0)
		return;
	*_emitterDDR |= _emitterBitmask;
	*_emitterPORT &= ~_emitterBitmask;
void PololuQTRSensors::emittersOn()
		return;
	*_emitterPORT |= _emitterBitmask;
// Reads the sensors 10 times and uses the results for
// calibration.  The sensor values are not returned; instead, the
// maximum and minimum values found over time are stored internally
// and used for the readCalibrated() method.
void PololuQTRSensors::calibrate(unsigned char readMode)
	if(readMode == QTR_EMITTERS_ON_AND_OFF || readMode == QTR_EMITTERS_ON)
		calibrateOnOrOff(&calibratedMinimumOn,
						 &calibratedMaximumOn,
						 QTR_EMITTERS_ON);
	if(readMode == QTR_EMITTERS_ON_AND_OFF || readMode == QTR_EMITTERS_OFF)
		calibrateOnOrOff(&calibratedMinimumOff,
						 &calibratedMaximumOff,
						 QTR_EMITTERS_OFF);
void PololuQTRSensors::calibrateOnOrOff(unsigned int **calibratedMinimum,
	int i;
	unsigned int max_sensor_values[8];
	unsigned int min_sensor_values[8];
	// Allocate the arrays if necessary.
	if(*calibratedMaximum == 0)
		*calibratedMaximum = (unsigned int*)malloc(sizeof(unsigned int)*_numSensors);
		// If the malloc failed, don't continue.
			return;
		// Initialize the max and min calibrated values to values that
		// will cause the first reading to update them.
			(*calibratedMaximum)[i] = 0;
	if(*calibratedMinimum == 0)
		*calibratedMinimum = (unsigned int*)malloc(sizeof(unsigned int)*_numSensors);
			return;
			(*calibratedMinimum)[i] = _maxValue;
	int j;
	for(j=0;j<10;j++)
			// set the max we found THIS time
			if(j == 0 || max_sensor_values[i] < sensor_values[i])
				max_sensor_values[i] = sensor_values[i];
			// set the min we found THIS time
			if(j == 0 || min_sensor_values[i] > sensor_values[i])
				min_sensor_values[i] = sensor_values[i];
	// record the min and max calibration values
		if(min_sensor_values[i] > (*calibratedMaximum)[i])
			(*calibratedMaximum)[i] = min_sensor_values[i];
		if(max_sensor_values[i] < (*calibratedMinimum)[i])
			(*calibratedMinimum)[i] = max_sensor_values[i];
void PololuQTRSensors::readCalibrated(unsigned int *sensor_values, unsigned char readMode)
	int i;
	// if not calibrated, do nothing
		if(!calibratedMinimumOff || !calibratedMaximumOff)
			return;
		if(!calibratedMinimumOn || !calibratedMaximumOn)
			return;
	// read the needed values
		unsigned int calmin,calmax;
		unsigned int denominator;
		// find the correct calibration
		if(readMode == QTR_EMITTERS_ON)
			calmax = calibratedMaximumOn[i];
		    calmin = calibratedMinimumOn[i];
		else if(readMode == QTR_EMITTERS_OFF)
			calmax = calibratedMaximumOff[i];
		    calmin = calibratedMinimumOff[i];
		else // QTR_EMITTERS_ON_AND_OFF
			if(calibratedMinimumOff[i] < calibratedMinimumOn[i]) // no meaningful signal
				calmin = _maxValue;
			else
				calmin = calibratedMinimumOn[i] + _maxValue - calibratedMinimumOff[i]; // this won't go past _maxValue
			if(calibratedMaximumOff[i] < calibratedMaximumOn[i]) // no meaningful signal
				calmax = _maxValue;
			else
				calmax = calibratedMaximumOn[i] + _maxValue - calibratedMaximumOff[i]; // this won't go past _maxValue
		denominator = calmax - calmin;
		signed int x = 0;
		if(denominator != 0)
			x = (((signed long)sensor_values[i]) - calmin)
				* 1000 / denominator;
		if(x < 0)
			x = 0;
		else if(x > 1000)
			x = 1000;
		sensor_values[i] = x;
// formula is:
int PololuQTRSensors::readLine(unsigned int *sensor_values,
	unsigned char readMode, unsigned char white_line)
	unsigned char i, on_line = 0;
	unsigned long avg; // this is for the weighted total, which is long
	                   // before division
	unsigned int sum; // this is for the denominator which is <= 64000
	static int last_value=0; // assume initially that the line is left.
	avg = 0;
	sum = 0;
	for(i=0;i<_numSensors;i++) {
		int value = sensor_values[i];
		if(white_line)
			value = 1000-value;
		// keep track of whether we see the line at all
		if(value > 200) {
			on_line = 1;
		// only average in values that are above a noise threshold
		if(value > 50) {
			avg += (long)(value) * (i * 1000);
			sum += value;
	if(!on_line)
		// If it last read to the left of center, return 0.
		if(last_value < (_numSensors-1)*1000/2)
			return 0;
		// If it last read to the right of center, return the max.
		else
			return (_numSensors-1)*1000;
	last_value = avg/sum;
	return last_value;
// Derived RC class constructor
PololuQTRSensorsRC::PololuQTRSensorsRC(unsigned char* pins,
  unsigned char numSensors, unsigned int timeout, unsigned char emitterPin)
// 'emitterPin' is the Arduino pin that controls the IR LEDs on the 8RC
// modules.  If you are using a 1RC (i.e. if there is no emitter pin),
// use an invalid Arduino pin value (20 or greater).
void PololuQTRSensorsRC::init(unsigned char* pins,
	PololuQTRSensors::init(numSensors, emitterPin, QTR_RC);
	unsigned char i;
	_portBMask = 0;
	_portCMask = 0;
	_portDMask = 0;
	_maxValue = timeout;
	for (i = 0; i < _numSensors; i++)
		if (pins[i] < 8)			// port D
			_bitmask[i] = 1 << pins[i];
			_portDMask |= _bitmask[i];
			_register[i] = &PIND;
		else if (pins[i] < 14)		// port B
			_bitmask[i] = 1 << (pins[i] - 8);
			_portBMask |= _bitmask[i];
			_register[i] = &PINB;
		else if (pins[i] < 20)		// port C
			_bitmask[i] = 1 << (pins[i] - 14);
			_portCMask |= _bitmask[i];
			_register[i] = &PINC;
// Example usage:
// The values returned are in microseconds and range from 0 to
// timeout_us (as specified in the constructor).
void PololuQTRSensorsRC::readPrivate(unsigned int *sensor_values)
	unsigned char i;
	unsigned char start_time;
	unsigned char delta_time;
	unsigned int time = 0;
	unsigned char last_b = _portBMask;
	unsigned char last_c = _portCMask;
	unsigned char last_d = _portDMask;
	// reset the values
	for(i = 0; i < _numSensors; i++)
		sensor_values[i] = 0;
	// set all sensor pins to outputs
	DDRB |= _portBMask;
	DDRC |= _portCMask;
	DDRD |= _portDMask;
	// drive high for 10 us
	PORTB |= _portBMask;
	PORTC |= _portCMask;
	PORTD |= _portDMask;
	delayMicroseconds(10);
	// set all ports to inputs
	DDRB &= ~_portBMask;
	DDRC &= ~_portCMask;
	DDRD &= ~_portDMask;
	// turn off pull ups
	PORTB &= ~_portBMask;
	PORTC &= ~_portCMask;
	PORTD &= ~_portDMask;
	unsigned char prevTCCR2A = TCCR2A;
	unsigned char prevTCCR2B = TCCR2B;
	TCCR2A |= 0x03;
	TCCR2B = 0x02;		// run timer2 in normal mode at 2.5 MHz
						// this is compatible with OrangutanMotors
	start_time = TCNT2;
	while (time < _maxValue)
		// Keep track of the total time.
		// This explicitly casts the difference to unsigned char, so
		// we don't add negative values.
		delta_time = TCNT2 - start_time;
		time += delta_time;
		start_time += delta_time;
		// continue immediately if there is no change
		if (PINB == last_b && PINC == last_c && PIND == last_d)
			continue;
		// save the last observed values
		last_b = PINB;
		last_c = PINC;
		last_d = PIND;
		// figure out which pins changed
			if (sensor_values[i] == 0 && !(*_register[i] & _bitmask[i]))
				sensor_values[i] = time;
	TCCR2A = prevTCCR2A;
	TCCR2B = prevTCCR2B;
		if (!sensor_values[i])
			sensor_values[i] = _maxValue;
// Derived Analog class constructor
PololuQTRSensorsAnalog::PololuQTRSensorsAnalog(unsigned char* analogPins,
  unsigned char numSensors, unsigned char numSamplesPerSensor,
// pins PC0 - PC7.
void PololuQTRSensorsAnalog::init(unsigned char* analogPins,
	unsigned char i;
	PololuQTRSensors::init(numSensors, emitterPin, QTR_A);
	_numSamplesPerSensor = numSamplesPerSensor;
	_portCMask = 0;
		_analogPins[i] = analogPins[i];
		if (analogPins[i] <= 5)	// no need to mask for dedicated analog inputs
			_portCMask |= (1 << analogPins[i]);
	_maxValue = 1023; // this is the maximum returned by the A/D conversion
// Example usage:
void PololuQTRSensorsAnalog::readPrivate(unsigned int *sensor_values)
	unsigned char i, j;
	// store current state of various registers
	unsigned char admux = ADMUX;
	unsigned char adcsra = ADCSRA;
	unsigned char ddrc = DDRC;
	unsigned char portc = PORTC;
	// wait for any current conversion to finish
	while (ADCSRA & (1 << ADSC));
	// reset the values
	// set all sensor pins to high-Z inputs
	ADCSRA = 0x87;	// configure the ADC
	for (j = 0; j < _numSamplesPerSensor; j++)
			ADMUX = _analogPins[i];			// set analog input channel
			ADCSRA |= 1 << ADSC;			// start the conversion
			while (ADCSRA & (1 << ADSC));	// wait for conversion to finish
			sensor_values[i] += ADC;		// add in the conversion result
	// get the rounded average of the readings for each sensor
		sensor_values[i] = (sensor_values[i] + (_numSamplesPerSensor >> 1)) /
	ADMUX = admux;
	ADCSRA = adcsra;
	PORTC = portc;
	DDRC = ddrc;
// the destructor frees up allocated memory
PololuQTRSensors::~PololuQTRSensors()
	if(calibratedMaximumOn)
		free(calibratedMaximumOn);
	if(calibratedMaximumOff)
		free(calibratedMaximumOff);
	if(calibratedMinimumOn)
		free(calibratedMinimumOn);
	if(calibratedMinimumOff)
		free(calibratedMinimumOff);
// mode: C++ **
// tab-width: 4 **
// end: **
I am in the process of investigating the problem further. The test I conducted on Friday was to connect the output of a potentiometer to an analog input and then to initialize the sensor library to use that pin. When I read uncalibrated sensor values, I was able to get expected readings from the input with the potentiometer on it. If you feel so inclined, you could conduct a similar test to make sure at least that works for you. Also, could you try reading uncalibrated sensor values with the sensor’s LEDON pin disconnected. This should ensure that the IR emitters are on. You can verify this if you have a digital camera without an IR filter (many cell phone cameras qualify); just point it at the sensor array and you should be able to see the IR LEDs glowing on the camera’s display if they are on.
- Ben
Hi Ben,
As you suggested, I tried looking at the sensors with my cell phone using the code below.
This is what I saw.
During the calibration phase, the emitters were on. Once the "i to 250’ loop is completed, the emitters never came back on.
Phil
#define SAMPLES 3
long  cnt = 0;
void setup()
  int i;
  Serial.begin(9600);
    Serial.print(".");
    delay(20);
  Serial.println();
  delay(100);
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  delay(10000);
void loop()
  int i;
    Serial.print("\t");
  Serial.println();
  delay(1000);                  // stop the program for some time
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  Serial.print(line);
  Serial.println();
Can you do the same test with the emitter pin (labeled LEDON on the sensor array) disconnected?
- Ben
Hi again Ben.
You may not believe this, but I’ve tested pretty much every combination you or I can think of. I guess I’m wondering if anyone else is using this software and if so, I would like to hear from them.
These are the results from using the following bit of test code (which I’ve posted before).
With the first test, the LEDON pin is contected. As you can see from looking at the code, it turns the LEDON pin off and on, delaying one second in between. Watching the ir emitters with my phone, they do indeed turn on and off each second.
With the second test, I disconnected the LEDON pin and as you would expect the ir emitters remained on at all times while the program ran.
Simple test code:
 * AnalogInput
int val0 = 0;       //
int val1 = 0;       //
int val2 = 0;       //
int val3 = 0;       //
int val4 = 0;       //
int val5 = 0;       //
long cnt = 0;
void setup() {
  Serial.begin(9600);
void loop() {
  cnt++;
  Serial.print(val0);
  Serial.print("\t");
  Serial.print(val1);
  Serial.print("\t");
  Serial.print(val2);
  Serial.print("\t");
  Serial.print(val3);
  Serial.print("\t");
  Serial.print(val4);
  Serial.print("\t");
  Serial.print(val5);
  Serial.print("\t");
  Serial.println();
The next test involves the Pololu Qtr Sensor class.
First with the LEDON pin connected. Looking with my phone again, the emitters are on during the (i = 0; i < 250; i++) loop in the setup phase, but turn off after that and do not come on again.
Next, with the LEDON pin disconnected. Viewing with the phone, the emitters are on continuously, even during the ‘loop’ phase.
The results from both of these test are identical and are included below, however, they show similar results to those from my previous tests, that is, it does not work.
I doubt very much if this code has been tested with an Arduino.
Qtr class code:
#define SAMPLES 3
long  cnt = 0;
void setup()
  int i;
  Serial.begin(9600);
    Serial.print(".");
    delay(20);
  Serial.println();
  delay(100);
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  delay(10000);
void loop()
  int i;
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
    Serial.print("\t");
  Serial.println();
  Serial.print(line);
  Serial.println();
These are the results from the Qtr class code:
0
1
2
Hi Ben,
How are we doing with this. Do you want to ask the developer if i can talk to him personally and if so you can email me his address? That might make things go a little quicker?
Best
Phil
You’re right, this library was never tested on a real Arduino, but it was tested on a mega168 microcontroller programmed using the Arduino environment, so the performance should match that of an Arduino. Unfortunately I haven’t had time to fully get to the bottom of this, but it’s the next task on my to-do list. I’ll be working on it tonight and I’ll post tomorrow to let you know what I’ve figured out. I apologize for the delay.
- Ben
