Hello I have purchased a Pololu VL53L0X time of flight sensor, after installing the libraries and running it on the Arduino Mega, the response I get on the monitor is 65535. Could you please help me fix this and get a proper reading.
What code are you running? How are you supplying power? Can you post pictures here that show your connections?
-Nathan
Thanks for your quick response it is very much appreciated.
I went back and checked all my connections and found a loose wire, and it is now working perfectly.
I am using the program from GITHUB, taken off the Pololu web and it is working good.
Again thanks for the support
Cheers
Andy
