My previous ISP (USBtinyISP) died, so I thought I’d try the Pololu USB ISP (for Orangutans and whatnot.) The fact that it was in stock at Jameco right down the road helped
I installed the ISP in Windows, and add it to programmers.txt with the following text:
pololu.name=AVR ISP v2
pololu.communication=serial
pololu.protocol=avrispv2
pololu.speed=9600
pololu.port=COM8
When I try to burn, the red LED turns on, and I get the following output:
C:\code\arduino>c:\code\arduino\arduino-1.0\hardware\tools\avr\bin\avrdude.exe -C C:\code\arduino\arduino-1.0\hardware\tools\avr\etc\avrdude.conf -v -
v -v -v -patmega328p -cavrispv2 -P\\.\COM8 -b9600 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xde:m -Ulfuse:w:0xff:m
avrdude.exe: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\code\arduino\arduino-1.0\hardware\tools\avr\etc\avrdude.conf"
Using Port : \\.\COM8
Using Programmer : avrispv2
Overriding Baud Rate : 9600
avrdude.exe: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude.exe: Recv: . [1b]
avrdude.exe: Recv: . [01]
avrdude.exe: Recv: . [00]
avrdude.exe: Recv: . [0b]
avrdude.exe: Recv: . [0e]
avrdude.exe: Recv: . [08]
avrdude.exe: Recv: A [41]
avrdude.exe: Recv: V [56]
avrdude.exe: Recv: R [52]
avrdude.exe: Recv: I [49]
avrdude.exe: Recv: S [53]
avrdude.exe: Recv: P [50]
avrdude.exe: Recv: _ [5f]
avrdude.exe: Recv: 2 [32]
avrdude.exe: Recv: t [74]
avrdude.exe: stk500v2_getsync(): found AVRISP programmer
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP V2
Programmer Model: AVRISP
avrdude.exe: Send: . [1b] . [02] . [00] . [02] . [0e] . [03] . [90] . [86]
avrdude.exe: Recv: . [02]
avrdude.exe: Recv: . [03]
avrdude.exe: Recv: . [0f]
avrdude.exe: Recv: . [18]
avrdude.exe: Send: . [1b] . [03] . [00] . [02] . [0e] . [03] . [91] . [86]
avrdude.exe: Recv: . [14]
avrdude.exe: Send: . [1b] . [04] . [00] . [02] . [0e] . [03] . [92] . [82]
avrdude.exe: Recv: . [04]
avrdude.exe: Recv: . [0a]
Hardware Version: 15
Firmware Version Master : 2.10
avrdude.exe: Send: . [1b] . [05] . [00] . [02] . [0e] . [03] . [94] . [85]
avrdude.exe: Recv: . [05]
avrdude.exe: Recv: . [10]
Vtarget : 0.0 V
SCK period : 134.6 us
avrdude.exe: Send: . [1b] . [06] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19] [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] 5 [35]
avrdude.exe: Recv: . [06]
avrdude.exe: Recv: . [c0]
avrdude.exe: Recv: . [c1]
avrdude.exe: stk500v2_command(): command failed
avrdude.exe: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude.exe: Send: . [1b] . [07] . [00] . [03] . [0e] . [11] . [01] . [01] . [00]
avrdude.exe: Recv: . [07]
avrdude.exe: Recv: . [11]
avrdude.exe done. Thank you.
The target is a factory-fresh ATmega328p DIP mounted in the socket of an Arduino UNO R3 board.
Note that it gets halfway, and then the thing just gives up. What’s wrong?
AAAAND this was because I had plugged in the ISP cable the wrong way – I wasn’t paying attention to the pinout of this programmer, and went by habit from my old programmer.
I thought it was right because the yellow LED was still flashing. However, when holding Reset down, the yellow LED stopped flashing, which is a sign that the programmer does not see +5V, which means the cable is reversed.
I’m letting this stand to shame me into forever double-check my connections before posting online, and as a help should someone else do the same thing.
