I am sorry if I am posting this in the wrong spot. I am having trouble with the pololu U1V11A adjustable power supply. After turning the pot, I cannot get the power supply to out 5v. It always says either 1.37 or 4.19. It will jump a lot between those values as well. Any help would be appreciated. Thanks!
We moved your post to “Other Pololu products” since there is not a specific regulator category.
I am sorry you are having trouble with your regulator. What are you using to power the regulator? Do you have any load connected to the output? Could you post pictures that show your whole test setup including the connections and solder joints and how you are measuring the output?
