I purchased
- Tamiya Twin Gear Box,
- Tamiya 70145 Narrow Tire Set (2 tires) and
- Pololu Robot Chassis RRC01A Solid Red.
The tires after fitting on the gear box axle could not be accommodated on the above chassis. Kindly advise what can I do ?
I purchased
What do you mean by “what can I do?” What parts are you committed to (are you asking for suggestions on how to modify the chassis or asking which wheels are intended for the chassis)? In general, I would recommend getting the truck tires that the chassis is designed for, and use the narrow tires in another robot. You could also design your own chassis to work with the different wheel size and have us laser cut it for you.
- Jan
