Hi, I’m using pololu QTR8A sensor, now the problem is the sensors from 0 to 6 give proper values, but the 7th and 8th no sensor does not. i did not break the board into two parts. Is there any different way two connect this last two sensors ? Another thing is, when the the 2nd and 3rd sensor is on a black line then suddenly they give some low reflect values ( like 1000). I have just purchased this module, so please help me wih this, i am using this code .(below)
[code]#include <QTRSensors.h>
#define NUM_SENSORS 8 // number of sensors used
#define NUM_SAMPLES_PER_SENSOR 4 // average 4 analog samples per sensor reading
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
// sensors 0 through 5 are connected to analog inputs 0 through 5, respectively
QTRSensorsAnalog qtra((unsigned char) {A0, A1, A2, A3, A4, A5, 10, 9},
NUM_SENSORS, NUM_SAMPLES_PER_SENSOR, EMITTER_PIN); // the first 6 sensors are connected with A0-A6 and the last two sensors are connected with pin 10 and 9 which are pwm enabled
unsigned int sensorValues[NUM_SENSORS];
void setup()
delay(500);
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // turn on Arduino’s LED to indicate we are in calibration mode
for (int i = 0; i < 400; i++) // make the calibration take about 10 seconds
qtra.calibrate(); // reads all sensors 10 times at 2.5 ms per six sensors (i.e. ~25 ms per call)
digitalWrite(13, LOW); // turn off Arduino’s LED to indicate we are through with calibration
// print the calibration minimum values measured when emitters were on
Serial.begin(9600);
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtra.calibratedMinimumOn[i]);
Serial.print(’ ');
Serial.println();
// print the calibration maximum values measured when emitters were on
Serial.print(qtra.calibratedMaximumOn[i]);
Serial.print(’ ');
Serial.println();
Serial.println();
delay(1000);
void loop()
// read calibrated sensor values and obtain a measure of the line position from 0 to 5000
// To get raw sensor values, call:
// qtra.read(sensorValues); instead of unsigned int position = qtra.readLine(sensorValues);
// print the sensor values as numbers from 0 to 1000, where 0 means maximum reflectance and
// 1000 means minimum reflectance, followed by the line position
for (unsigned char i = 0; i < NUM_SENSORS; i++)
Serial.print(sensorValues[i]);
Serial.print(’\t’);
//Serial.println(); // uncomment this line if you are using raw values
Serial.println(position); // comment this line out if you are using raw values
delay(250);
}[/code]
I’m using Arduino UNO.
