hi
i’m making a line follow robot, i’m using the qtr-8rc and the orangutan sv 328
the last year i made a similar robot with the qtr-8rc and arduino
http://www.youtube.com/watch?v=E-iqCHxxBI4&list=UUpipeBKOJCC8XDvWUGEQF6g
this year i use the oragutan sv 328
i have a trouble with the sensor and the code
After the calibration i use this line code to give the value of the ubication of the white line
when the middle sensors are in the midle of the white line,the value that the code give me is about 2500 instead of the 3500 value.
after this problem i tried the next line code instead with a black line
when the middle sensors are in the midle of the black line, the value that the code give me is about 3500
i think that the problem is something related to the calibration or ther read the white line
here is all my code
[code]#include <pololu/qtr.h>
#include <pololu/orangutan.h>
#include <pololu/digital.h>
#define M1 30
#define M2 30
int main() {
clear();
print(“LYNX”);
set_motors(0,0);
int lastError = 0;
unsigned char qtr_rc_pins[]={IO_D0, IO_D1, IO_C0, IO_C1, IO_C2, IO_C3, IO_C4, IO_C5};
qtr_rc_init(qtr_rc_pins,8,2000,255);
wait_for_button_press(BUTTON_A);
clear();
print("calibrating");
int i;
for (i = 0; i < 250; i++) // make the calibration take about 5 seconds
qtr_calibrate(QTR_EMITTERS_ON);
delay(20);
clear();
print("press B");
wait_for_button_press(BUTTON_B);
//set_motors(M1,M2);
while(1)
{ unsigned int sensors[8];
int position = qtr_read_line_white(sensors, QTR_EMITTERS_ON);
//int position = qtr_read_line(sensors, QTR_EMITTERS_ON);
int error = position - 3500;
int motorSpeed = (1/4) * error + (7) * (error - lastError);
lastError = error;
int m1Speed = M1 - motorSpeed;
int m2Speed = M2 + motorSpeed;
if (m1Speed < 0)
m1Speed = 0;
if (m2Speed < 0)
m2Speed = 0;
if (m1Speed >45)
m1Speed = 45;
if (m2Speed > 45)//50
m2Speed = 45;
//set_motors(m1Speed,m2Speed);
clear();
lcd_goto_xy(0,0);
print_long (error);
lcd_goto_xy(0,1);
print_long (position);
return 0;
}[/code]
