Hi, i am having trouble independantly operating 2 buttons to 3 servos attached to a 6 pin maestro. 2 servos are assigned to button 1 and one other servo to button 2. i have two examples i have tried… shown below. my first example works but in most cases the servos dont activate on the first push of the button it requires 3-4 button pushes before the servo moves. the second example using wait_for_button_press, only one button works and ignores the other button completley. example 3 i have tried to merge the two but still no luck only as this time it onyl works as a sequence not by frame. my ideal goal is for button 1 to operate 2 servos together in sync frame by by frame(with each button press) not as a sequence… .and button 2 to operate the third servo indepedantly.
button 1 = channel 0
button 2 = channel 1
servo 1 = channel 2
servo 2 = channel 3
servo 3 = channel 4
example 1
# When the script is not doing anything else,
# this loop will listen for button presses. When a button
# is pressed it runs the corresponding sequence.
begin
button_a if sequence_a endif
button_a if sequence_aa endif
button_b if sequence_b endif
button_a if sequence_bb endif
repeat
# These subroutines each return 1 if the corresponding
# button is pressed, and return 0 otherwise.
# Currently button_a is assigned to channel 0,
# button_b is assigned to channel 1, and
# button_c is assigned to channel 2.
# These channels must be configured as Inputs in the
# Channel Settings tab.
sub button_a
0 get_position 500 less_than
return
sub button_b
1 get_position 500 less_than
return
# These subroutines each perform an arbitrary sequence
# of servo movements. You should change these to fit
# your application.
sub sequence_a
4000 2 servo 500 delay
9000 3 servo 500 delay
return
sub sequence_aa
9000 2 servo 500 delay
return
sub sequence_b
4000 4 servo 500 delay
return
sub sequence_bb
9000 4 servo 500 delay
return
Example 2
goto main_loop # Run the main loop when the script starts (see below).
# This subroutine returns 1 if the button is pressed, 0 otherwise.
# To convert the input value (0-1023) to a digital value (0 or 1) representing
# the state of the button, we make a comparison to an arbitrary threshold (500).
# This subroutine puts a logical value of 1 or a 0 on the stack, depending
# on whether the button is pressed or not.
sub button
return
# This subroutine uses the BUTTON subroutine above to wait for a button press,
# including a small delay to eliminate noise or bounces on the input.
sub wait_for_button_press
wait_for_button_open_10ms
wait_for_button_closed_10ms
return
# Wait for the button to be NOT pressed for at least 10 ms.
sub wait_for_button_open_10ms
get_ms # put the current time on the stack
begin
# reset the time on the stack if it is pressed
button
if
drop get_ms
else
if drop return endif
endif
repeat
# Wait for the button to be pressed for at least 10 ms.
sub wait_for_button_closed_10ms
get_ms
begin
# reset the time on the stack if it is not pressed
button
if
else
drop get_ms
endif
repeat
sub button1
return
sub wait_for_button1_press
wait_for_button1_open_10ms
wait_for_button1_closed_10ms
return
sub wait_for_button1_open_10ms
begin
button
if
drop get_ms
else
endif
repeat
sub wait_for_button1_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
# An example of how to use wait_for_button1_press is shown below:
# Uses WAIT_FOR_BUTTON_PRESS to allow a user to step through
# a sequence of positions on servo 1.
main_loop:
begin
4000 4000 frame
5000 5000 frame
6000 6000 frame
7000 7000 frame
8000 8000 frame
repeat
sub frame
2 servo
3 servo
return
begin
4000 frame
5000 frame
6000 frame
7000 frame
8000 frame
repeat
sub frame
4 servo
return
example 3
begin
repeat
sub button_a
return
return
begin
button
if
drop get_ms
else
endif
repeat
get_ms
begin
button
if
else
drop get_ms
endif
repeat
sub button_b
return
sub wait_for_button_b_press
wait_for_button_b_open_10ms
wait_for_button_b_closed_10ms
return
sub wait_for_button_b_open_10ms
begin
button
if
drop get_ms
else
endif
repeat
sub wait_for_button_b_closed_10ms
get_ms
begin
button
if
else
drop get_ms
endif
repeat
# your application.
sub sequence_a
4000 frame
5000 frame
6000 frame
7000 frame
8000 frame
repeat
sub frame
2 servo
3 servo
return
sub sequence_aa
4000 frame
5000 frame
6000 frame
7000 frame
8000 frame
repeat
sub frame
2 servo
3 servo
return
sub sequence_b
4000 frame
5000 frame
6000 frame
7000 frame
8000 frame
repeat
sub frame
4 servo
return
sub sequence_bb
4000 frame
5000 frame
6000 frame
7000 frame
8000 frame
repeat
sub frame
4 servo
return
