Hi, using C++, using the commands:
setSpeed, setAcceleration, setTarget
is there a command or one of the above to disable a servo once moved?
You can disable the output of a Maestro servo channel by setting the target position to 0. For example, to disabling the output of channel 3 would look something like this:
maestro.setTarget(3, 0);
However, please note that some digital servos will continue holding their last position when they stop receiving a signal.
