In the maestro control center, I created a Sequence 6. I then copied all sequences to script and hit the apply settings button.
I now have a sequence called Sequence_6 in the script tab.
My issue is whatever I call it in python I get NameError: name ‘Sequence_6’ is not defined.
I’ve tried it in quotes, without quotes, with a space, with an underscore but nothing seems to work.
I’m running python 3.7.3 on a Raspberry Pi 4.
Any help would be greater appreciated.
It sounds like you are using the maestro.py library. The runScriptSub function expects a subroutine number, not the name of the subroutine, so that line should probably look something like this:
servo.runScriptSub(6)
That function uses the Maestro’s “Restart Script at Subroutine” command, which is documented in the “Serial Script Commands” section of the Maestro user’s guide. I recommend reading the description for that command to understand how to use it. In particular, please note that the subroutine is numbered based on the order it is defined in your script, not based on how you name it, and the subroutine should not end with the RETURN command.
