Dear Pololu support,
I have been using your 3-Channel Wide FOV Time-of-Flight Distance Sensor Using OPT3101 (Pololu #3412) for a few years.
I am very satisfied with its functioning, but unfortunately a few days ago one of the upper infrared sensors came loose from the PCB during a competition and I was no longer able to find it.
I replaced it with a similar one I had at home, but it doesn’t work well.
I therefore have 2 requests for you:
1 - Is it possible to have the code of the IR sensor (see image), so as to be able to replace it and return to correct functioning of the Pololu #3412?
2 - I noticed that the OPT3101 component allows you to change the I2C address, but I don’t see the possibility of doing so on the Pololu #3412 PCB circuit. Do you have any suggestions on this?
Thanks in advance
