I am using the Pololu TreX dual motor Controller [pololu.com/product/777] to drive Pololu34:1 Metal Gearmotor with 48 CPR Encoder [pololu.com/product/2273]
The intended voltage for the motors is specified as 6V but the operation range is 3-9V. The TreX driver supplies ~3.3V to drive the motors. Will the 3.3V operation voltage affect the motor performance in any way?
I am using serial commands to control the velocity. For the same velocity command given to left and right motors, the current consumption is different for both sides (current value acquired using external resistor in series). Is it expected behaviour ?
Example : for set left and right motor to velocity 30(decimal), I get current values 400mA and 300mA respectively.
Thanks,
Rupesh
